416to212
12-16-2008, 11:43 AM
So I've been reading a lot about different polishes and techniques in regards to polishing the tips of my Greddy SP2. Needless to say there are a lot of products out there and a lot of different schools of thought.
First of all, I'd like to say that I have used multiple polishes most notably:
Never Dull (cheapest) - Only shines up your tarnishing - doesn't remove it.
English Custom (most expensive) - I didn't like the consitency (watery), further more this polish was not agressive enough for my semi-bad tarnished tips on another Greddy I used to have. I didn't think it was worth the money. I'd say this is a product that is best used to maintain an already relatively clean piece of metal without leaving any swirling - it's a finishing polish and will dissappoint you if you have bad tarnishing.
For my application on the new (second hand) Greddy SP2 I bought recently, I needed to take a more agressive approach. As you can see in the pictures the exhaust tips are the worst I've ever seen in my life - mostly black and brown, and these stains are not just carbon residue, it's discolored metal. Plus there was melted plastic on them. Out of this world bad....
I decided to use an slightly agressive polish - Simichrome. It's a medium consistency paste that feels slightly gritty. I've also noticed that my tarnishing becomes lessened with this product and I think it's why a lot of coin collectors use this stuff on their coins.
http://www.aaa-publishing.com/images/simichrome.jpg
In addition to the Simichrome polish I applied the product with #0000 (extremely fine) steel wool using medium pressure. The steel wool left only extremely light swirls (lighter swirls than in my paint) on the metal but this was only the first step in the polishing. I will be following up the polishing by applying Mother's Mag and Aluminum Polish with a Mother's Mini PowerBall to get the smoothest mirror shine possible. I've seen a Borla Video that suggests that Brass wool would be an even better alternative to Steel Wool and can be bought at Marine/Boating supply stores. Brass is softer than stainless steel so it would be less likely to scratch the tips.
Here are the pictures:
Before (with flash)
http://i118.photobucket.com/albums/o108/dkny10001/IMG_6215.jpg
Before (no flash)
http://i118.photobucket.com/albums/o108/dkny10001/IMG_6216.jpg
Mid polishing with Simichrome and #0000 Steel Wool (no flash)
http://i118.photobucket.com/albums/o108/dkny10001/IMG_6218.jpg
http://i118.photobucket.com/albums/o108/dkny10001/IMG_6220.jpg
After polishing with SimiChrome and #0000 Steel Wool (no flash)
Despite what you may see in the pictures, the tips are completely clear of any tarnishing and gold coloration. They are completely clear and colorless!
http://i118.photobucket.com/albums/o108/dkny10001/IMG_6222.jpg
EDIT: After using SimiChrome and #0000 Steel Wool, I followed up with Mother's Mag and Aluminum polish using a Mother's Powerball-mini. Though you can't see the results in pictures the final look was smooth as hell and near-mirror-like. Also the light scratching from the steel wool was minimized even further.
Hope this helps those of you with the Greddy and with the RB exhaust who need an agressive solution to a simple problem.
Before (with flash)
Before (no flash)
