newbie problem. HELP!
Old Dec 16, 2008 | 02:01 AM
rx8bb6evo8's Avatar
Hi guys, first of all im a new rx-8 guy, bought 04 rx-8 couple of weeks ago...
It's been coo... got new rims and suspension on the way already....
but here's my problem I bought my car as is on a Mazda dealership in CA....
then by the time i got home i notice my foglights wasn't working so as the high beams....
looked on the bulb already and doesn't seem like busted or something... its also weird
imagine 4 bulb at the same time busted? checked the fuses already, and its all good, then
I asked somebody from weaksauce shop they told me the same thing fuses or relay or
bulb... I haven't check the relays tho... Where could i find that?
Is anybody here had a the same problem like mines?
any help will be greatly appriciated
THanks!
Old Dec 16, 2008 | 02:15 AM
DOMINION's Avatar
I don't buy Kool-Aid
2 places to look.
1 is next to you intake the box to the bottom right.
2 is a box by your clutch where the driver door opens.
Old Dec 16, 2008 | 04:31 AM
krijpipudht's Avatar
Hi guys! My name is Tony.
From: San Francisco Bay Area 94542, USA. Earth. Solar System. Milky Way
broken switch?
Old Dec 16, 2008 | 09:28 AM
EDZRIDE's Avatar
2005 White GT
Are you trying to run the fog lights when you're headlights are on hi-beam?
Old Dec 16, 2008 | 09:29 AM
rx8bb6evo8's Avatar
^^^ broken switch? so it means both switch broken?
also high beams? u think so?
Old Dec 16, 2008 | 09:37 AM
heyarnold69's Avatar
Rotary wanabee
also check the ground on the ballast if you have hid lights.
Old Dec 16, 2008 | 10:09 AM
EDZRIDE's Avatar
2005 White GT
The fog lights won't work if the high beams are on; try the fogs and low beams.
Old Dec 16, 2008 | 11:38 AM
rx8bb6evo8's Avatar
yes i do have HID.... so after i check the ground for ballast what should i dO?
rx8bb6evo8's Avatar
no either way it wont work tho....
Old Dec 16, 2008 | 04:16 PM
auwen's Avatar
There are ways to test the relays and the switch in the car itself. Both are going to require a multimeter. For the relays, pull em and there should be two sets of two pins, one set should be a copper color and the other a silver metallic. If the relay is good you should get a resistance value on one(this is the coil portion of the relay) and an open on the other (this is the actual switching part, without the current applied to the coil it will read open). If either or both of these are 0ohms you have a bad relay, also if both read infinite resistance you also have a bad coil. For the Switch in the car the best way I can think of is to again pull the relay and plug a multimeter into the car itself (you may have to move the leads around as I can't tell you off the top of my head which two are for the signal to the relay). Set the multimeter to voltage and see if the voltage changes. If it does then its probably not the switch, if it does not then the switch or the interconnecting wiring between the switch and that relay is broken.
Hope this helps.
Old Dec 16, 2008 | 04:40 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah auwen has it down perfectly to make it a little more clear on which terminals to test on the relay i'll give u some pointers....on the bottom of the relay there should b numbers(on the side that gets plugged into the fuse box) test resistance between the numbers labeled 85 and 86 this is your coil of the relay...then with the lights off you should have a very small amount of resistance from terminals labeled 30 and 87a (.1 to .2 of an ohm) and you should have OL or out of limits (or possibility reads a 1 depending on meter) between 30 and 87 then when you power on the two should switch....
30 to 87a OL
30 to 87 low resistance
p.s. if they numbers dont match and they are numbers 1-5 which is the siemans type of relay they numbers comprehend like this
1 and 2 is 85 and 86
3 is 30
4 is 87a
5 is 87 test the same way
Old Dec 16, 2008 | 07:06 PM
rx8bb6evo8's Avatar
thanks for the help appreciated....
imma try to check this on the weekend... thanks again!
Old Dec 16, 2008 | 07:19 PM
04RX8man's Avatar
hey post ur location so maybe a local person can help u out!!!
Old Dec 16, 2008 | 11:16 PM
Correct.
RevMeHarder
Jun 1, 2026 02:30 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
tommy26Germany
Sep 29, 2015 10:33 AM
ndamix
Sep 18, 2015 03:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
