Need Fuel Pump Help
Old Dec 14, 2008 | 06:56 PM
MAZDADIKE's Avatar
Need Fuel Pump Help
any one give me a idea to get this damn fuel pump out without raking something..
does it turn, spin magically come out...
thanks in advance
Old Dec 14, 2008 | 06:59 PM
I8U's Avatar
I8U
There is a threaded ring around the outside of the pump, you must remove that first, it spins counter clock wise. Problem with that is, it can be a bitch and most the time will break in the process. When I worked on mine I went to the dealership and bought a new ring before I even started the work just in case. Once the ring is off the pump comes right out.
Old Dec 14, 2008 | 07:09 PM
MAZDADIKE's Avatar
counter clock wise..... alright im on the right track.
i have been doing that but i started reading about a tool and **** and got all confused
Old Dec 14, 2008 | 07:10 PM
hakuna matata!
^ getting the necessary tool will make it loads easier.
Old Dec 14, 2008 | 07:32 PM
MAZDADIKE's Avatar
yeh i here that its a pain i nthe *** haha
Old Dec 14, 2008 | 07:39 PM
StealthTL's Avatar
Metatron
Big flat screwdriver and mallet, tap the lugs counterclockwise, gently.
There are some little 'ears' that prevent the ring turning, make sure they are pulled away from the edges.
The tabs are a lot stronger than they look, but the dealer wants $70+ for a new ring.....
S
Old Dec 14, 2008 | 09:51 PM
I8U's Avatar
I8U
Stealth is right on, we use a flat tip screwdriver and mallet to remove our on the race cars. Make sure once you remove it though, you check to make sure the o-ring that sits under it is free of cuts so you get a good seal once you re-install it.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
mdl0209
May 23, 2019 05:46 PM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
