Agency Power rattling tip HELP
Old Dec 11, 2008 | 01:06 PM
ballistc's Avatar
the tip of my AP exhaust is loose and rattles.
anyone have a similar problem? or knows how to fix it?
Old Dec 11, 2008 | 04:40 PM
04RX8man's Avatar
Rotary Powered Countryboy
tighten it...I'm not sure how the exhaust is set up but if it's just the tip rattling then there there should b a screw/bolt that holds the tip on you just tighten it and u will b good to go
Old Dec 11, 2008 | 09:45 PM
ballistc's Avatar
the things that hold the tip the the pipe isnt something you can screw or tighten...
any other ideas? should i just stick a piece of metal or something in the cracks?
Old Dec 16, 2008 | 05:32 PM
toneskii707's Avatar
suck my smog
I got the same problem, the hanger that's right next to the differential will vibrate against it what I did was cut off the extra part of the metal hanger right after the rubber hanger where it turns downward, my driver side tip rattles also but I learned to deal with It, but to fix that you can let the car idle let the tips get hot and with a glove or a stick push on the tip whichever way Its making the rattling and let It melt it away let me know how it goes.
RevMeHarder
Jun 1, 2026 02:30 PM
Mane
Nov 20, 2015 12:16 PM
Emmanyei
Sep 19, 2015 11:12 AM
titaneum_grey
Sep 16, 2015 11:51 PM
