phantomkid
12-10-2008, 04:39 PM
Hey guys, I couldnt find much help on what wires go to which for hooking the Innovative Lm1 wideband auxilary output to The greddy emanage ultimate af option harness. Is anyone running the LM1 with the EMU. if so which wires go to the white and grey and did you have the output voltage range 1-5v????
thanks so much guys Brian
09Factor
12-11-2008, 11:06 AM
I did this when I had my EMU. Off the top of my head I don't recall .
Don't take my word but wht = wht and blk=grey.
I'll check tonight and let you know. All the AFR info is good for is logging. If you're trying to use the afr data from the LM1 to auto tune the EMU, it dosen't work very well if at all.
phantomkid
12-19-2008, 07:46 PM
the lm1 output wires are a white and red???? im thinking white with white red with grey??
paulmasoner
12-19-2008, 09:31 PM
I am pretty positive mazdamaniac used to have his LM1 into the EMU.... you might try searching his website or or EMU threads here
09Factor
12-30-2008, 09:03 PM
Only 20 days have passed....
this is how my LM-1 to EMU was wired.
looking at the back of the EMU where the 2 "Option" ports are. The Lm-1 analog out put wire I have is Red, White and a Copper shield.
LM-1 position on Emu connector
Red Left
Wht Center (don't for certain remember if this is necessary)
Copper (grnd) Right
As you already know you will have to configure one of the Option ports for what type of input you are using..
Hope this makes sense if you haven't found the answer already
