Squeeling noise when reversing
Old Dec 9, 2008 | 08:35 AM
mx6_to_rx8's Avatar
Hi All,
My 04 has developed a slight problem: when the car is in reverse it makes a really high pitched squeeling noise... I have no idea what it is. The noise is only there when it is in reverse and I am giving it gas, but it does not make a sound if it is reverse and I have the clutch down.
any thoughts?
thanks
Old Dec 9, 2008 | 10:59 AM
justjim's Avatar
justjim
Is it only when the car is moving in reverse? If so, it may be your wear indicators on the brake pads notifying you of worn brake pads. If that is the cause the squeal will eventually happen when you go forward as well.
Old Dec 9, 2008 | 03:33 PM
refugeefrompistons's Avatar
squeal or a high pitch whirl?
Old Dec 9, 2008 | 03:47 PM
Are you sure you're not backing up over babies? They can make a preety high pitch squeel...
Old Dec 10, 2008 | 08:39 AM
mx6_to_rx8's Avatar
justjim- It's only when the car is moving and in reverse (or if it is is neutural and the car is rolling backwards)-- and also, it happens even when the clutch is down (i said early it didn't, but confirmed last night that it did). It is only happening when I go forward.
refugeefrompistons- its much more of a high pictched squeal--- sounds like metal rubbing on each other, but not grinding---- it hard to explain.
thanks for you help
Old Dec 10, 2008 | 09:08 AM
ndhoffma's Avatar
Is it in gear all the way?
Old Dec 10, 2008 | 10:11 PM
8 Maniac's Avatar
Senior Member
I think it's probably your brake wear indicators... can you locate the sound? If it's the brakes, it's most likely going to be the fronts.
Old Dec 11, 2008 | 08:14 AM
mx6_to_rx8's Avatar
ndhoffma-- yup it's in gear all the way.
8 Maniac-- the sound is definately comming from the back--- are there also break indicators in the rear?
theblinkof
Oct 4, 2023 05:24 PM
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
