60,000 Tune up
Old Dec 7, 2008 | 04:16 PM
szym0n's Avatar
60,000 Tune up
My car is almost at 60K and I would like to get some stuff replaced/changed.
So far I got the following.
-Spark Plugs/Wires
-Ignition Coils
-Cabin Filter
-Differential Fluid change
-Transmission fluid change
-Power Steering fluid change
-Radiator Flush
What else would be good on a 60K service.
I'm planning to take it to a Mazda dealer as well so I would like to know an estimate too if possible, a rough estimate is fine.
Thanks guys
Old Dec 7, 2008 | 04:26 PM
EdwardsB's Avatar
Registered RX-8 User
I hope you did not pay for power steering fluid?
Old Dec 7, 2008 | 04:29 PM
learycd's Avatar
Hold DSC for 7 Sec
for the fluids:
get your car on a lift, for any type of work u need done, go the the mechanic can u just swap these fluids out....hand him the bag of redline fluids...and put 40 bucks in his pocket (or less if you know him )
Old Dec 7, 2008 | 04:44 PM
04RX8man's Avatar
Rotary Powered Countryboy
Yeah hopefullly u didnt buy power steering fluid because our cars have electronic steering no fluid....that's a good list other than that and just do the exchanges yourself it will save u quite a bit of money for labor
Old Dec 7, 2008 | 05:09 PM
szym0n's Avatar
Can anyone link me for a DIY to replace the coils if there is one.
Old Dec 7, 2008 | 05:20 PM
ken-x8's Avatar
Another dealer price reference point...
They'll usually charge about $100 to change the cabin air filter. The filter lists for about $35. Look up the DIY. It's maybe five minutes work, if you move slowly and savor every step.
Ken
Old Dec 7, 2008 | 07:18 PM
Low Fly'n 8's Avatar
Recent dealer quote for changing trans and diff fluid. Me supplying Redline: $160 labor. Do it yourself.
Old Dec 7, 2008 | 08:29 PM
Tim Tim Tim's Avatar
auto suckkssssss
I guess I should probably do the same. im at 65k now. Luckily i just got a new motor 10k ago so the coolant, coils, plugs and stuff are all new.. Does the tranny fluid (automatic) and rear diff fluid need changed yet?
Old Dec 7, 2008 | 08:53 PM
learycd's Avatar
Hold DSC for 7 Sec
yes it does, if you havent changed it yet mazdas service says at 60k miles so you a bit over
i would even recomend changing it more often than that, its a 40 dollar job in terms of the fluids if your buying redline. and your tranny/diff will thank you in the long run
so maybe every 30k? or year? or whatever your abuse level requires
Old Dec 7, 2008 | 09:43 PM
szym0n's Avatar
Im going to get a quote from jiffy lube like RxDoogone suggested and see how much they will want for rear diff & tranny fluid, and the radiator flush i will take to this shop by my house, and the plugs/coils/cabin filter I will do myself.
Would it be smart getting new Spark plug wires along with the coils and new spark plugs?
Old Dec 11, 2008 | 03:54 PM
auto suckkssssss
I guess ill be getting on doing my diff and tranny fluid soon. I hate changing fluids, all that work time and money and you dont even go faster when your done lol
Old Dec 11, 2008 | 04:10 PM
HERO's Avatar
if it hasn't ever been done, Id change my brake/clutch fluid as well if I were you.
Old Dec 13, 2008 | 09:23 PM
DOMINION's Avatar
I don't buy Kool-Aid
Thumbs up
I do all my own work so meh.
Old Dec 20, 2008 | 06:02 PM
astrozoom's Avatar
If you can get access to a lift, all the fluids are pretty easy to change. There is one spark plug that is kind of hard to reach, but if you can get the left front tire off, it is much easier. Other then that the spark plugs are pretty easy to do as well.
Old Dec 22, 2008 | 01:19 PM
Never L8's Avatar
^Don't forget to check your turn signal fluid!
Good suggestions on here! Roll with it.
Old Dec 22, 2008 | 04:28 PM
Socket7's Avatar
ಠ_ಠ
Ask them show you the old power steering fluid when you bring it in.
Did anyone mention rotating your tires yet?
Also, this is one car that can benifit from one of those oil flush machines. it will let you get all the dirty oil out of your oil coolers that a normal oil change cant get. Might be a good "special treat" for your car.
Old Dec 23, 2008 | 04:56 PM
leep133's Avatar
I just had my 8 serviced at the dealership, pretty much did what you mentioned and paid $700
Old Dec 24, 2008 | 01:10 AM
flush the clutch slave cylinder..
it does matter ..
Old Dec 24, 2008 | 01:29 AM
hakuna matata!
i don't know how to put that kindly..
Old Dec 24, 2008 | 01:33 AM
13RoTrB's Avatar
simon if you want i can take your 8 along with mine to my schools shop and do the differential fluid change there for free, im planning to change mine right after spring break...
Old Dec 24, 2008 | 10:06 AM
leep133's Avatar
Yeah... but what can you do... Im a stickler for having the sealership do all my work...
$500 for the major service and $200 for the plugs + installation
Old Jan 5, 2009 | 09:28 PM
Ceez76's Avatar
Ceez76
Jiffy lube changed my trans/diff fluid last years. I think I paid 50 some odd bucks. I got 60,000 miles on mine and I too had an engine replaced about 10,000 miles ago.
Old Jan 5, 2009 | 09:54 PM
04RX8man's Avatar
I would not trust JIFFY LUBE for anything i would do it all myself.....
