Name that Broken Vacuum line!
Old Dec 7, 2008 | 12:19 PM
Socket7's Avatar
ಠ_ಠ
Unhappy Name that Broken Vacuum line!
So, I went out to install my coil kit today and while puzzling over how to take the air box and accordion tube out, I noticed something bad. I have a broken vacuum line. Can anyone tell me what this one does? I plugged the broken end and it pulled something of a vacuum on my finger. I couldn't really feel it, but when I pulled my finger away i could hear the hiss of air being sucked in.
Old Dec 7, 2008 | 12:28 PM
It's an intake leak...not really a vac leak ( before the TB) It's either the jet air, crankcase vent or the OMP lines...can't remember which is the lower one.
If you need the elbow...find someone local with an intake or turbo..they will have that lying around. I have 6..you can have one if you want, but it would be a lot faster getting one local
Old Dec 7, 2008 | 12:46 PM
deadphoenix52's Avatar
meh.
i broke one doing my plugs and wires. i just super glued it back together. made sure there were no leaks. no problems yet. *knock on wood*
Old Dec 7, 2008 | 01:35 PM
AE92's Avatar
i had mines slip off before (K&N Typhoon) and it made a whistling sound. but looks like in your case. you can just go the hardware store and get a fitting of some sort and just stick it where the plastic would go between the hose and the intake tube.
Old Dec 7, 2008 | 02:18 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah you should be able to just go to a hardware store and get something to fix it right up...
Old Dec 7, 2008 | 04:21 PM
Socket7's Avatar
ಠ_ಠ
I know I can go get a new fitting. I want to know what it is.
Old Dec 7, 2008 | 04:26 PM
To be named later's Avatar
Now with 25% more fluff..
Looks like a Huey to me.
Albert?
Desmond?
Sincerely,
No More Oldsmobiles
Old Dec 7, 2008 | 04:37 PM
Top one is MOP air line
Middle one is Jet Air Line
That one is the Vent line to "crankcase"
Old Dec 7, 2008 | 04:54 PM
Socket7's Avatar
ಠ_ಠ
cool. Now to find the part # for the damn thing. Any advice for getting whats left of it out? Just a set of pliers or something else?
Old Dec 7, 2008 | 10:52 PM
max5roadster's Avatar
INDY RX8 CLUB - Officer
Now's your chance to install a catch-can. Or plug it and run a breather filter off your oil filter neck.
Old Dec 7, 2008 | 11:15 PM
just a push in elbow....pliers will work
Did you find the part #?
Old Dec 8, 2008 | 12:24 AM
lshu's Avatar
Driving makes me :)
same thing happened to me when changing my plugs and wires. Those elbows get fragile over time, need to be careful next time.
I went to my dealership's parts department and got a replacement piece for $12. Ripoff for a tiny piece of plastic but more piece of mind to get it fixed right away.
Old Dec 8, 2008 | 09:09 AM
Socket7's Avatar
ಠ_ಠ
I wish i had even gotten to the wires and plugs! I found it like that when I popped the hood. Must have busted it while working on my stereo a while back and never noticed.
Max5, The breather isn't needed on 07's like mine. mazda re-routed the overflow deep into the intake manifold now, rather then having it dump behind the air filter. This is a different hose from the one people put an oil catch can on.
Old Dec 8, 2008 | 09:35 AM
NO FEAR ! NYCGPS IS HERE !
the part you need is FEMJ-13-758 , Its like a 5 something 6 bux part.
Dont thank me. Buy me a beer one day
(P.S. in case u wanna look it up, its in 1330a in service manual)
Old Dec 8, 2008 | 03:55 PM
Socket7's Avatar
ಠ_ಠ
Guess I'm gonna have to get a fitting from Kragen or something. Mazda wants 10 bucks and 2 days for it. Yeah right. Ain't nothing special about a 3/8th inch barb elbow connector.
Old Dec 8, 2008 | 04:23 PM
hakuna matata!
ive broken those elbows 2x getting it out and the first time I was putting back my stock intake from mazdaspeed I misplaced all 3!
local mazda dealer charged me $19 for all 3.. but they were there the next morning
Old Dec 8, 2008 | 04:36 PM
NY to the rescue!
Might just get these in advance since I know they're going to break eventually.
Old Dec 8, 2008 | 06:49 PM
HeavyMetal699's Avatar
Now I'm going to have to check mine. It sounds like I have an air leak in the engine bay but I wasn't sure if it was a normal whistle or not. I'm guessing probably not.
Old Dec 8, 2008 | 07:23 PM
TrochoidMagic's Avatar
is adjusting valve lash
NO.....
that's about the worst thing you can do.
you mean you want the pressure to rise from oil in the crankcase cooking off and evaporating in the engine bay making things oily, rather than having the oil vapors make its way into the intake lubricating moving parts in the intake???
i wouldn't recommend parts that aid in breaking one's car rather than improve performance or function.
Old Dec 8, 2008 | 11:34 PM
What are you talking about its a 5 something bux part :P
but if u just need one + shipping then yea ... its a 10 bux part
Yep, its nothing special, u can get those elbow thing at Autozone for maybe 2-3 bux for like 5 of them (maybe more maybe less, but I swear I seen them before)
Old Dec 8, 2008 | 11:35 PM
hakuna matata!
dude! koeppel mazda charged me $9 for it when I broke one.. but when i bought 3 the first time it was $19..
Old Dec 8, 2008 | 11:56 PM
They told me loads of bs when I took my car in for a clogged cat (bs like oh ur intake is causing it, if u have map we can reprogram it blah blah blah)
oh, did u get my pm?
Old Dec 9, 2008 | 12:00 AM
hakuna matata!
i would have never taken my car there for service even if I didn't know about Wayne..
which pm was that? o.O
Old Dec 9, 2008 | 12:05 AM
I was asking did ya find out where can u get those plastic "twist in" plugs/bolts for the fender and stuff.
cuz I probably gonna get like 100s of those. As long as its not 75 cents each like what Mazda has been selling their stock "crap"
Old Dec 9, 2008 | 12:07 AM
hakuna matata!
OHH.. like I said my dad got those from his shop.. ill see if he can ninja a box or at the least maybe he knows where they get it from!!
