Engine Swap EMS?
Old Dec 4, 2008 | 04:09 PM
mike1324a's Avatar
Need'd a Turbo
Engine Swap EMS?
Just for kicks and giggles to all the more experienced tuners out there such as CRH or MM, how realistic is it to run a different 13b(ie 13b-re or 1b-rew) off the computer in the rx8? Basically the computer running our renesis is pretty powerful, and as we are seeing, tuning is ever improving with reflashers such as the AP. How possible would it be to do an engine swap and run it with the rx8 computer and AP? Im not thinking any wild high horsepower with a fully built engine, but just fairly light mod numbers (maybe smaller single turbo) that are common from the 7 community.
Old Dec 4, 2008 | 04:23 PM
Red Devil's Avatar
60-1 and GT35R are common in the RX-7 community. If you want something smaller, why wouldn't you just stick with the Renesis?
Old Dec 4, 2008 | 04:29 PM
G3tR3DDY2GR3DDY's Avatar
still a legitimate question. I would love to use the rx8 ecu with a cobb on my REW swap instead of spending over 1200 on a microtech.
Old Dec 5, 2008 | 11:16 AM
mike1324a's Avatar
Need'd a Turbo
The GT35r and 60-1 was what I was thinking about. The difference is they make over 400whp and 300wtq all day, no problem and the renesis simply doesn't. Regardless, anyone have any idea if it could work?
Old Dec 10, 2008 | 01:45 PM
mike1324a's Avatar
Need'd a Turbo
no one? mm?
Old Dec 12, 2008 | 03:18 PM
truemagellen's Avatar
Attracts tree branches
I disagree :D
Old Dec 12, 2008 | 04:59 PM
chickenwafer's Avatar
Nope
The sensors are different, mainly the eccentric shaft position sensor and the RX-8 PCM won't read the FD sensor.
You could try swapping sensors, but then the ignition is still a problem since the RX-8 ignition system works differently as well.
Old Dec 13, 2008 | 01:54 AM
mike1324a's Avatar
Need'd a Turbo
Originally Posted by truemagellen
I disagree :D
Touché.
Old Dec 13, 2008 | 01:56 AM
mike1324a's Avatar
Need'd a Turbo
Yeah the eccentric shaft sensor would be an issue. However would the ignition be an issue? Would it not be possible to just use the 8's ignition system. How different are the plugs?
ps. Chickenwafer, your 8 is so sweet.
Old Dec 13, 2008 | 08:45 PM
The stock ignition is very weak but you can use it if you have the right plugs...you would need to upgrade the ignition though to get anywhere
Old Dec 14, 2008 | 02:29 PM
mike1324a's Avatar
Need'd a Turbo
Oh of course! Not the stock ignition system but an upgraded rx8 system.
vapor2
Nov 3, 2020 03:38 PM
WingleBeast
22
May 23, 2016 09:22 PM
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
