Oil was white and nasty today
Old Dec 4, 2008 | 03:51 PM
vglnte1's Avatar
So, I've had the car for a few months, and the oil has always been black...of course.
Then today I checked it as it was low....as always, fugging oil burner...and it was white and foamy. I added oil and kept checking, all white. Im not to knowledgable on these motors yet. I called Mazda and they said this is 100% normal for rotaries and RX8's. Is this true?
Not sure if it matters but, its been below 20 degrees here for a couple days.
Thoughts?
Old Dec 4, 2008 | 03:56 PM
never fear, Jedi is here.
white / foamy substance on the dipstick is normal. This most commonly found during the cold winter months so no need to panic.
Just make sure your oil is always topped off and keep on zoom-zooming.
http://www.finishlineperformance.com...50-06-1664.pdf
P.S. Look for a thread by Zoom44 about Winter. Lots of good stuff there
Old Dec 4, 2008 | 04:17 PM
vglnte1's Avatar
thanks!
Old Dec 4, 2008 | 04:48 PM
xtremetreadwear's Avatar
I have also seen this in my 8, even before it got cold. When i talked to Mazda, they said that it is a natural by product of gas and oil mixtures in the engine. This, however doesn't make much sense to me because I have never seen this happen in a snowmobile or other 2 cycle engines. After talking to another mechanic, he said this is caused my moisture in the engine. What exactly is happening with this moisture, i'm not really sure, but it has something to do with cold weather and condensation. Nothing to worry about, just all the more reason to make sure your oil changes are done on time.
Old Dec 4, 2008 | 06:50 PM
04RX8man's Avatar
Rotary Powered Countryboy
it does not have to be terrible cold just cold enough outside that the heat from the oil makes the insde hot and the ouside temp causes condensation inside the oil dipstick tube cause i milkshake type texture....u r all fine....
Old Dec 4, 2008 | 07:29 PM
05rx8mazda's Avatar
B.I.G
I never knew about this. this has never happened to me before. i live in Tx and the coldest it got here last year was what 30 degrees if even that low
Old Dec 4, 2008 | 11:53 PM
Rick's Avatar
Old Dec 5, 2008 | 12:22 AM
Nubo's Avatar
Lubricious
My oil's a little too white & nerdy.
http://www.azlyrics.com/lyrics/weird...hitenerdy.html
05TR1CH
Apr 18, 2023 04:56 AM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
uZu
Dec 30, 2015 12:35 PM
ShadowGryphon
Aug 23, 2015 02:46 PM
dbarber
Jul 25, 2015 01:34 PM
