Are all 4 Injectors different?
Old Dec 3, 2008 | 02:51 PM
Gabgoobie's Avatar
I learnt by coincidence that not all 4 spark plugs are the same on the RX8. I now wonder if the injectors are also different? Between two engines that I have, I have 4 yellow injectors and 4 pink ones. Which ones go in which port? which injectors are the best selection for the 2004 manual model?
thanks.
Old Dec 3, 2008 | 02:57 PM
if all 4 of your spark plugs are NOT the same. you have a problem
4 spark plugs in total. 2 leading should be the same heat range and type. same thing goes for 2 trailing.
For injectors, its about the same case as the spark plugs. Just look it up in service manual.
Old Dec 3, 2008 | 04:41 PM
LionZoo's Avatar
road warrior
6 ports have 6 injectors.
Old Dec 3, 2008 | 05:58 PM
04RX8man's Avatar
Rotary Powered Countryboy
Yeah I'm lost of how yo have 8 difffent injectors 2 diffterent sets of 4 and ur car has 6 injectors to begin with....or you have the 4 port and did not tell us....please post location
Old Dec 4, 2008 | 03:17 AM
Gabgoobie's Avatar
Sorry for the confusion. I have 4 ports not 6 on my engine. The spark plugs for the 4 ports ARE NOT ALL THE SAME. Two of them are one type and another two are another type. the Two trailing plugs are both the same and the leading two plugs are the same.
I have two engines from two cars that have been used as a pool of parts to make one good one. Between the two engines I have 8 injetcors. These are 4 pink ones and 4 yellow ones. I do not know which order they came out or from which engines they came. One of the 2 engines is a 2005 and the other is a 2004. To make the best set of injectors, which ones should I put in which port?
Old Dec 9, 2008 | 01:22 PM
Silver06's Avatar
Zoom Zoom....
Please search... This info is not only available on this site, it has been STICKIED.
First post:
Originally Posted by MazdaManiac
I wanted to put all of this in one place for reference.
PRIMARY INJECTORS
RED 290cc
6-PORT SECONDARY INJECTORS & PRIMARY 2 INJECTORS
YELLOW 380cc
4-PORT SECONDARY INJECTORS
BLUE 480cc
Injectors are Bosh disc-type, high impedance (13 ohm) with a Denso connector.
The thread is here: https://www.rx8club.com/series-i-tech-garage-22/fuel-injector-info-150432/
Old Dec 9, 2008 | 01:53 PM
I never "directly" said 6 port has 4 injectors. 4 port can have 4
READ YOU n00b !
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
extreme_rotary
Sep 30, 2015 09:53 AM
Jb4ker96
Sep 27, 2015 10:06 PM
RAE008
Sep 20, 2015 01:32 PM
