View Full Version : AMSOIL Fluid Questions
CarAndDriver
12-02-2008, 05:31 PM
First off, sorry to everyone who have had some issues using RP Maxgear in their manual transmissions. I bought some for my transmission and differential and have yet to put them in. Appreciate the updated feedback to avoid using it in the transmission.
My questions:
1. I think I will be using AMSOIL for the transmission, is this what people are using?
Manual Transmission & Transaxle Gear Lube 75W-90 (GL-4)
2. Can I still use the RP MaxGear in the differential? If I go with AMSOIL, it looks like I should use Severe Gear 75W-90?
LionZoo
12-02-2008, 05:49 PM
1. Is that the GL-4 fluid? If it is, then that should be good to go. If you want an alternative to Amsoil, you can try the Motorcraft XT-M5-QS.
2. You can still use Royal Purple in the diff. The Severe Gear will also work back there.
CarAndDriver
12-02-2008, 05:53 PM
^ Yes, that is the GL-4 only fluid. I know now to avoid any GL-5 in the transmission fluid. Thanks about the diff.
04RX8man
12-03-2008, 06:04 PM
should work very very well with it that's what i'm thinkin about using in mine
tunerwannab
12-03-2008, 09:57 PM
I put that in my transmission monday and so far so good. I will wait until my next "spirited" drive before giving my impressions though.
CarAndDriver
12-05-2008, 12:30 AM
Look forward to hearing your feedback.
