throttle body
Old Dec 1, 2008 | 11:00 PM
am22's Avatar
throttle body
This week end I want to clean my throttle body but I’ve never done it before. Can anyone help me where do I start? Is there a procedure I can go by? Oh and btw would I need a new gasket for the throttle body after I take it off? ,thanks
Old Dec 1, 2008 | 11:39 PM
TrochoidMagic's Avatar
is adjusting valve lash
it doesn't require a new gasket. just remove the (4) 12mm bolts and stick those bolts into the TB coolant passage as you remove it.
grease around where the brass plates meets the metal so it doesn't stick.
i had mine polished to take advantage of this procedure (hint hint)
Old Dec 2, 2008 | 01:02 AM
BDC's Avatar
BDC
BDC Motorsports
Easily removed. TrochoidMagic's suggestions are great. Also, have a peek at this:
http://bdc.cyberosity.com/v/Throttle+Bodies/Rx8/
Old Dec 2, 2008 | 08:47 AM
foo77's Avatar
4th batch : Apr 03'
a thread about it
https://www.rx8club.com/showthread.p...=throttle+body
Old Dec 2, 2008 | 12:50 PM
kersh4w's Avatar
Hit & Run Magnet
polishing the TB has a performance effect?
why?
Old Dec 2, 2008 | 06:24 PM
BDC's Avatar
BDC
BDC Motorsports
why?
Well, it's not just polishing but yeah. I grind a bit of the metal out and remove the 'lip' at the bottom that's above the throttle butterfly. Also flare out the top prior to finishing it up. It has an effect and it's fairly substantial.
B
Old Dec 2, 2008 | 06:42 PM
04RX8man's Avatar
Rotary Powered Countryboy
How much effect is this showing?
Old Dec 2, 2008 | 06:46 PM
05rex8's Avatar
sold the 8... :(
B
interesting...
Old Dec 2, 2008 | 09:21 PM
am22's Avatar
Thank for all the help you guys. I’ll let you know how it goes.
Old Dec 2, 2008 | 11:42 PM
BDC's Avatar
BDC
BDC Motorsports
I don't have any dyno results yet. I've tested it on one non-turbo 8 (mostly stock) and one turbocharged 8 using the Mazsport hardware. The results are the same as they've been on the older rotaries both non-turbo and turbo: Quicker throttle response, noticably better midrange (NA), slightly higher peak power (both NA and turbo), slightly louder exhaust (both), more whistly turbo, and lots better boost response.
B
Old Dec 3, 2008 | 06:53 PM
05rex8's Avatar
sold the 8... :(
B
oooo more whistley turbo.....I may have to look into doing this over this winter...
Old Dec 3, 2008 | 09:18 PM
thank you BDC.
thats what i basically did to mine. i smoothened it out near the venturi lip, and rounded out the entrance edge of the TB where the coupling meets the TB. not soo much boring over, but more focused on polishing and smoothening out.
i also took advantage of the coolant hoses by connecting them together with a small fluid filter. just trying to knock out 3 birds with 1 stone.
call it OCD... but on a motor where we can't get multi-angle valve jobs, perfecting on minor touch-ups is all worth the time to me.
i guess i'm the type who actually polishes the openings of a brand new headers before i actually install it. quality of parts over quantity...
anyway, nicely cleaned TB.
Old Dec 4, 2008 | 02:14 AM
cody6766's Avatar
I may have to do this soon. I know just a polish made a distinguishable difference in my grand prix that I used to drive. I don't see why the 8 wouldn't benefit from it too.
mr dremel, here I come!
Old Dec 6, 2008 | 08:27 PM
^^it won't be be felt on the butt dyno.
but there leaves room for other mods with the coolant hose now just running in circulation.
hmm..... looks like i might have to do something about that.
future mod!
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
D13
Oct 1, 2015 07:55 AM
Jb4ker96
Sep 27, 2015 10:06 PM
