Been to the dealer 3 times and told all normal.
Old Dec 1, 2008 | 09:34 PM
Grimacus's Avatar
Ok I am just wondering since the dealer I took my car too has told me the issues that I currently am having are normal operation but you be the judge. 2005 RX8 36,000 miles.
1st. Car makes a whistle/scrape sound at 5-6k rpm under load. Dealer told me its normal, just ports opening.
2nd. Car is making a tick sound every 8-10 seconds, seems to come from the engine area, almost like a A/C compressor kicking in but my A/C/defrost is off, guess you could say it also sounds like when you shut your car off and you can hear click sounds coming from your manifold when hot. Dealer said that was normal, just a pump feeding oil to the motor. Seems to only happen when warm.
3rd. When at a stop and back up and then move forward I get this loud clack sound from the front end, took it to the dealer and said was normal, needed upgraded brake pads not covered by warranty, said something about the brake pads shifting, clips moving but nothing to worry about.
4th. When I press or depress my clutch pedal I get this rubberish squeak sound, dealer said they fixed something on my service rod, but its still squeaking, I showed them the bulletin on replacing the cltuch pedal but they said they couldnt repeat the sound, when I took it in of course it wasnt doing it, figures...
I guess my only other option is to take it to another dealership, but its a 25 miles drive to the next mazda dealer.
Old Dec 1, 2008 | 10:16 PM
max5roadster's Avatar
INDY RX8 CLUB - Officer
1-normal
2-need better description if possible, but sounds alright
3-plausable
4-could be binding, but it has to do it for them to replace. Sucks, but gotta have them replicate it.
Old Dec 1, 2008 | 10:29 PM
Grimacus's Avatar
On the 2nd one, its a click sound, I've only so far notice it when i've warmed the car up, its about 8-10 seconds interval, cant hear it once I rev up the car alittle.
Old Dec 1, 2008 | 10:30 PM
zoom44's Avatar
1 yes
2 if you have the fan on and air directed at your feet the defrost will be on no matter whether you have it selected or not. the compressor will cycle, depending on outside temp.
3. when you were parked? then thats correct if you have read the manual you would find that after every time the car is started the brakes do a self check after going faster than 5 or 7 mph(forget the number just now). the sound is the brakes pumping very fast once
4 your clutch pedal is going to break. take it to them DRIVE with them and show them the sound. don't let them try to replicate without you in the car.
Old Dec 1, 2008 | 11:06 PM
ahh... the last one sounds like th bearing. Its know big deal. works fine but squeeks.
Agree with the others on 1,2,3
Don't panic. This car makes different noises.
Most car do the samething but the piston engine noise covers them up.
The rotory is super quiet so yo hear more.
Old Dec 1, 2008 | 11:19 PM
Grimacus's Avatar
I showed them the bulletin for the pedal, said it was fine, instead they told me they fixed some issue with the service rod. I know the bearing sound to be normal at least on this car from what I heard but the noise im getting is coming from the pedal area. Oh and I turned off the heater/AC fan and radio and I can hear the click sound from inside the cabin and louder if I stick my head out of the window, cant pinpoint, sounds like its coming from the back of the engine or on top.
Old Dec 2, 2008 | 03:56 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah 1 is normal..2: not really sure wha tthat cold b the brakes is possible for a clip to b rubbing and clutch pedal i have that squeak but it's coming from the transmission housing on the pedal i also can't figure out what exactly it is...
Old Dec 3, 2008 | 12:37 AM
Grimacus's Avatar
Well talked with the dealer i've been dealing with, basically they told me im hearing things and would have to show the service manager the sounds before my car could be looked into again by a tech. So I decided to take my car to another dealer to see if I get better results.
Old Dec 3, 2008 | 09:28 AM
zoom44's Avatar
im pretty sure thats what i said
Old Dec 3, 2008 | 07:27 PM
Grimacus's Avatar
Well I dropped my car off at another dealer, and told me the clicking sounds are normal. They had to order a part for my clutch pedal some switch was going bad, so had to leave my car overnight. They also found my drink holder was loose and replaced that. Still waiting on the news of the brake caliper issue.
Now they told me my car is overdue for transmission service $139.95, need to change my air filter $70.00, need to have my coolant flushed 129.00, and last my fuel system/fuel injectors need to be cleaned $139.00 yay, now I can do the air filter myself but im wondering is it cheaper to have the others done by a non-mazda tech like some local shop?
Old Dec 3, 2008 | 07:42 PM
tunerwannab's Avatar
I have an air filter for sale. PM me if interested
Old Dec 6, 2008 | 08:17 PM
I8U's Avatar
I8U
You can do the transmission service, air filter, and coolant flush yourself for a quarter of the price they are asking.
Old Dec 6, 2008 | 09:07 PM
04RX8man's Avatar
yeah yo9 can do all of that cheaper...and for the "injector cleaner" you can do that for like 10 bucks get seafoam from walmart its the same stuff
Old Dec 8, 2008 | 10:08 PM
Grimacus's Avatar
I wish, last time I messed with my car I ended up breaking off a hose to a fuel filter and had to tow the car into the shop being a Saab. Right now im looking for a rotary expert in the dallas fort worth but no cigar.
Old Dec 14, 2008 | 11:16 AM
Grimacus's Avatar
Well got my car back last week, they replaced my clutch switch, no more squeegee sound, but now im getting a click/vibration when I start to depress the clutch from the floor. Told the dealer about my idle, when I am above .900 - 1k rpm I dont notice it but when it drops below .900 it feels like my engine is sputtering/shaking, dealer said that was normal. I already had my motor mounts replaced and yesterday changed out my air filter, to me this just doesnt seem normal but two dealerships said it was normal. I had two 1987 Rx7 and both ran smoothly.
Old Dec 14, 2008 | 12:29 PM
Go to your local club meet....
You will see the RX 8 has a rough idle.
Old Dec 14, 2008 | 01:43 PM
04RX8man's Avatar
yeah u need to hit up a local meet and have some more experienced rotary guys/girls take a loook at it...a little far for me to come or i would!
Old Dec 16, 2008 | 10:55 PM
Grimacus's Avatar
LOL actually as cold as its been here, I would come to Florida
uZu
Dec 30, 2015 12:35 PM
GrAfiX
Aug 24, 2015 08:08 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
