Better brakes for the 8?
Old Dec 1, 2008 | 07:15 PM
Never L8's Avatar
I'm in need of replacing pads and rotors, and I found these on Ebay. Just wondering if anyone's replaced the stock setup with something similar? It seems like a good deal...but we know what that could mean!
I've read all of the related threads and I know the stock brakes are some of the best out there. I also know that there will be inquiries into my driving style and why I would change the stock system. Answer...My 8 is my daily driver and the only thing I track is my bike. I'm just looking for equivelant performance and am wondering what the experts with experience think about changing into a system such as this. Thanks in advance!
http://cgi.ebay.com/ebaymotors/04-08...Q5fAccessories
Old Dec 1, 2008 | 09:11 PM
TopGear8's Avatar
mkuhnracing.com
You won't notice a difference with different rotors...Also some people stay away from drilled/slotted rotors because sometimes they are prone to cracking. A good brake pad people use is the Hawk HP Plus.
Old Dec 1, 2008 | 09:22 PM
SouthFL's Avatar
I love the HP Plus, but then again, my car sees a track day about once every 6 weeks. IMO they're overkill for only street use.
Old Dec 1, 2008 | 11:08 PM
mikeschaefer's Avatar
I wanna rock! Rock!
I searched on this a month ago and the consensus among members with respected opinions and experience under their belts was that if you're looking to upgrade from OEM and you just daily drive your car, go with Hawk Ceramic. So I bought them. And I like them... a lot.
If all you're looking for is equivalent performance to OEM... then uh why not go OEM?
If you mean equivalent performance to your bike, you won't get it.
Old Dec 1, 2008 | 11:12 PM
Easy_E1's Avatar
Run for the hills! Are those the actual rotors? If those are the rear rotors why don't they look like they are vented? They look solid. Or maybe I need glasses.
Old Dec 2, 2008 | 01:49 AM
LionZoo's Avatar
road warrior
I'm sure it's just a generic picture.
Old Dec 2, 2008 | 02:43 AM
Brian Major's Avatar
anyone running mazdaspeed pads? i would think they would be a nice upgrade from stock.
Old Dec 2, 2008 | 09:48 AM
justjim's Avatar
justjim
I clipped this response of mine from another recent similar post, and I think its relavant here as well.
Originally Posted by justjim
I'm relatively new to the RX8, I have 2 track sessions in the advanced group at Sebring with my new RX8, but I have quite a bit of street and track experience dealing with high performance braking issues with my former car, which was a FWD Acura RSX Type S. My first comment is that relatively speaking the RX8 brakes are superb right out of the box. I seriously doubt that most people will overdrive the OEM brakes on the street.
That said, if you really want to stop faster, buy stickier/larger tires. The OEM brakes are fully capable of setting off the ABS at any speed you would safely encounter on the street. As a result, the limiting factor is not braking efficiency but tire traction.
If you do overdrive the OEM brakes because you have humongous tires and you drive like a lunatic, I would suggest Axxis Ultimates, as they have the best coefficient of friction and heat range for a street performance pad per dollar. If money is no object, try Carbotech Bobcats or Cobalt GT Sports. Any street performance pad is going to dust more than the OEM pads, get used to it.
If you track the RX8 more than once, you should be using dedicated track pads such as Carbotech XP10/XP8s or Cobalt XR2/XR5s. If I was going to spend money to upgrade the brakes for the track I would get a 2-piece floating hat front rotor. An interim lower cost upgrade would be to get a set of curved vane 1-piece rotors. But I had no issues whatsoever with track pads on OEM brakes and R-compound tires on the very brake intensive Sebring road course.
Spend your money elsewhere.
Old Dec 2, 2008 | 12:14 PM
I8U's Avatar
I8U
You really think so? I can tell you from first hand experience that your statement is incorrect. I have been on track with the Colbat XR2/GTS pads with Racing Brake 2-piece drilled/slotted rotors...braking distances were cut nearly in half versus the same pad combo on stock rotors. I think that is one hell of difference, myself. Yes, drilled/slotted tend to crack but you can always go with a slotted/dimpled rotor to help solve that problem.
Old Dec 2, 2008 | 01:07 PM
LionZoo's Avatar
road warrior
I don't doubt that there might be a difference, but cut in half? Unless you suddenly got F1 brakes and tires, I don't think that's going to happen.
Old Dec 2, 2008 | 02:12 PM
I8U's Avatar
I8U
^Obviously, you have never driven this setup before. I can say honestly half the distance because I have seen/felt it first hand in my many ride-a-longs in our cars. On stock rotors with our Cobalt pad setup, coming into turn 1 at VIR, braking had to start at about 400-300 ft, with the same car on Racing Brake slotted/drilled rotors and Cobalt pad setup, we didn't have to start breaking until 200-150 ft before the turn.
Old Dec 2, 2008 | 02:59 PM
fastlaneracing's Avatar
Rotor User
Carbotech XP8 is great pads.
Old Dec 2, 2008 | 03:56 PM
justjim's Avatar
justjim
On the track where you would have exceeded the OEM pads temp range and with R-compound tires, yes I would agree with you. Your'e talking apples and oranges here with track experience vs. street. On the street I don't believe you would see a significant difference. Just to be clear I use the Cobalt XR1/XR5 combo on the track with R-compounds so I have some experience with the comparison.
Old Dec 2, 2008 | 04:06 PM
LionZoo's Avatar
road warrior
Are you on race tires? There's gotta be something more factoring into this as a stock RX-8's 60-0 braking distance is 110 feet. You might gain a small amount going to Cobalt's, but even if you don't halving the stopping distance would meant the car is stopping from 60 in 55 feet; which is very unbelievable to me.
What is the driver profile like? The only thing I can see is the race tires have more grip and so the braking force, which previously was more than sufficient for street tires, is now less than the tire grip and so stockers aren't capable of activating the ABS anymore. Also, perhaps the initial bite is harder where the stock rotors took a bit more pedal travel for engagement and the driver is a bit smoother rolling onto the brakes. Regardless, halving the distance is hard to believe for me. Perhaps the stock rotors were overheating and it's actually the extra cooling that's combating the fade?
Old Dec 2, 2008 | 04:12 PM
mac11's Avatar
Rotary , eh?
He is not talking about stock PADS, but stock ROTORS.
From what he has said the only change in the setup sounds like the rotors with pads & tires being constant.
Old Dec 2, 2008 | 06:16 PM
justjim's Avatar
justjim
Well I tend to agree with the original statement by Topgear8 that different rotors don't generally improve stopping distances. Rotors pretty much perform the same if you are talking about the same diameter. Drilled or slotted, they don't stop you any quicker. When talking about rotors of the same diameter, the only signifcant improvement is in thermal dissapation when comparing straight vaned to curved vane, curved vane being better; and comparing 1-piece fixed hat rotors to 2-piece floating hat rotors, the 2-piece being better cooling and less weight. But on the street those thermal advantages are small and the primary factor in stopping distance is still going to be the tires.
On the track where you are really heating things up with R-compound sticky tires, with the thermal advantages of the curved vane, and the thermal and weight advantage of a 2-piece floating hat rotor, I can see that a different rotor would be a distinct advantage.
Now if you go to a larger rotor you are not only affecting the thermal dissapation but you are changing the clamping force on the rotor. This brings with it a whole host of problems with front to rear brake bias unless you make appropriate changes at the rear. Nonetheless, if the OEM brake pad and rotor combination can instantly set off the ABS, it is the tires that are the limiting factor in stopping the car.
Old Dec 2, 2008 | 09:08 PM
I8U's Avatar
I8U
Thank-you, atleast someone understood the setup change. Besides I take it by the comments, some don't think I have any merit stating what I have seen first hand. I mean really, I didn't work on a pro Grand-Am race team this year so apparently I'm wrong.
Old Dec 2, 2008 | 09:11 PM
mac11's Avatar
Rotary , eh?
Believe me, I don't have any questions as to why people associated with actual racing or parts manufacturing don't want anything to do with internet forums - this car or any other.
Don't be too discouraged, there are some of us listening and appreciate your input.
BTW, how fun was Mid-O this year in the rain? weeeeeee!
Old Dec 2, 2008 | 09:16 PM
SouthFL's Avatar
All this talk of track grade pads and rotors when the OP simply wanted a street pad/rotor set. Lol.
The heat dissipating benefits of a 2 piece rotor and frictional operating range of trackable pad would not be perceivable (nor suitable in terms of pad compound) on the street.
Old Dec 2, 2008 | 09:20 PM
mac11's Avatar
Rotary , eh?
I'm not trying to start a pissing match or argument of any kind but I do like the XP8's myself. They have a strong initial bite and low enough operating range they can be used as a street pad if you are willing to put up with the noise and dust but also are a trackable compound to a certain point.
If I were looking for every last bit of stopping power on the street (not sure why but for arguments sake?) I would run these all the time.
Old Dec 2, 2008 | 09:38 PM
SouthFL's Avatar
Bobcat would be the appropriate Carbotech compound for his request.
Old Dec 2, 2008 | 09:45 PM
mac11's Avatar
Rotary , eh?
I don't belive in hard and fast rules for anything in life so I don't like to say things like that. I'm sure in this situation more than likely he would want the bobcats because of the excessive noise and dust from the xp line. But the XP8's could be used as street pads if you wanted to deal with that. Just sayin. could.
Old Dec 2, 2008 | 10:16 PM
LionZoo's Avatar
road warrior
Believe me, I'm listening to what you have to say, but from my vehicle engineer perspective, it's a little hard to believe a rotor change could halve the stopping distance of a car. Notice I'm trying to brainstorm reasons; from a logical standpoint your claims don't add up to simply the rotor change. Acceleration, or deceleration in this case, is the square of force and so to halve the stopping distance would require FOUR times the stopping force. A simple rotor change would leave the lever arm of the braking system the same and so clamping force should not change. The only way I can see it happening is the superior thermal properties of the two-piece eliminating fade, but that is a lot of heatsoak for the standard rotor to go through. You might have claimed to see it first hand, but remember this is the internet, and more than that, as an engineer I really want to know the REASON WHY. I'm not willing to simply accept X comments at face value unless I find the logic behind it, and I'm trying hard at the moment to do so.
Old Dec 2, 2008 | 10:22 PM
mac11's Avatar
Rotary , eh?
You two are talking about completely different metrics here.
You are talking stopping distance, he is talking braking distance into a corner where the car does not come to a stop.
Old Dec 2, 2008 | 10:41 PM
LionZoo's Avatar
road warrior
They're still pretty related; both are measures of stopping distances and a function of the force of the braking system. My question would be, what other variables changed at the same time? Also, was the test done over multiple days and how experienced was the driver on the circuit?
