Power steering failure due to the fluid?
Old Dec 1, 2008 | 06:09 PM
expo1's Avatar
He's as bad as Can
The RX-8 doesn't use power steering fluid. It uses electricity
Old Dec 1, 2008 | 06:13 PM
expo1's Avatar
He's as bad as Can
If your 8 was recently in an accident then the body shop that 'fixed' the car is the place to go. If not then the dealership.
Old Dec 1, 2008 | 09:10 PM
Check the connections. They have been know to get dirty.
Old Dec 3, 2008 | 06:07 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah check connections then go to the dealer if not.....sort of sucks not having a fluid type rack but it is better in many other ways...just can't realy fix it unless u r really experienced with those tings
Old Dec 3, 2008 | 07:56 PM
Socket7's Avatar
ಠ_ಠ
Flush the electrons out of the wire and replace them with new ones.
It seems like the connector located below the coolant overflow hose tends to go bad when the coolant boils over and spills out onto it. Might want to start by checking there. Beyond that, no clue.
HMSS013
Series I Do It Yourself Forum
Apr 9, 2023 09:13 AM
drebbrnator
Dec 27, 2018 07:02 PM
Billy Marcial
Mar 1, 2018 06:50 AM
Corey Monterico Carolino
Sep 2, 2015 11:34 PM
atmd
Aug 19, 2015 12:43 PM
