leaking some kinda fluid but dont know from where
Old Nov 30, 2008 | 12:37 PM
TRUOMEGA's Avatar
04 GT 6-speed
04, rx8 6-speed no mods. Theres a golden clear fluid that i spotted under the car when changing my oil. I know its not oil cause my oil was black and this fluid was a golden clear color. It was located directly in front of the oil pan on the metal brace that travels from left to right along the front end of the car. The leak is almost in the center but more towards the passenger side. If u look from the top i can see 4 clear thin tubes that appear to carry the same lubricant as what i spotted dripping along the bottom. The leak doesn't appear to be bad because theres no fluid on the floor of my driveway. Any ideas and what exactly is leaking? The car is out of the manufacturers warranty so id like to try to fix it myself. At this time, i dont notice any difference in the way the car drives/performs, however, i would like to get it repaired before something fails. Thanx in advance for any info given.
Old Nov 30, 2008 | 12:51 PM
Check your air filte/airboxr...if it was filled too quickly at an oil change...it tends to run down the breather into the intake into the filter box...and from there out the hole onto the cross member and into that area....
Old Nov 30, 2008 | 01:08 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah check that ^^^ the only fluids that are that color are unused oil and brake fluid so u could double check your brake fluid is full but i'd say most likely it jus tthe oil
Old Nov 30, 2008 | 11:05 PM
Damn! don't be lazy! Check it! Is it oil, radiator fluid.
Hell put your finger in it and check it out.
Old Nov 30, 2008 | 11:22 PM
alnielsen's Avatar
From the sound of your description, that is part of the device that injects oil into the rotor to lubricate the apex seal.
Wipe your finger on the fluid. Feel it, Smell it. Is it oily? Does it smell like brake fluid. If necessary, taste it. Antifreeze has, I'm told, a sweet taste to it.
Old Dec 1, 2008 | 01:50 PM
04RX8man's Avatar
yeah antifreeze is sweet that's y animals will try to drink it if u spill some but will kill them...
Old Dec 1, 2008 | 02:31 PM
mikesol's Avatar
gas kilometerage
I had a cat that drank like a cup of antifreeze at 2 or 3 years old and lived to 17. Mighty beast.
If it's the oil metering pump, I wouldn't drive the car at all, just to be safe...
Old Dec 2, 2008 | 10:24 PM
RenKat's Avatar
Water Pump
Check the bottom weep hole on the water pump.
I had one fail and the small leak after passing through the inner seal and bearing had this color.
Old Dec 2, 2008 | 10:30 PM
Brettus's Avatar
Boosted Kiwi
did you throw it in the freezer to see if the antifreeze worked ?
Old Dec 2, 2008 | 10:37 PM
Renesis07's Avatar
Vtak just kicked in yo!!
I drink a cup of antifreeze every morning! It helps keep the hair in the chest
Old Dec 2, 2008 | 11:11 PM
hakuna matata!
Taste it.
Old Dec 2, 2008 | 11:16 PM
alnielsen's Avatar
The OP looks like a drive-by poster. Fires a shot then runs away.
Old Dec 2, 2008 | 11:47 PM
I wouldn't tell anybody to "try" to taste "possible" anti-freeze.
Cuz it takes as little as 3-4oz of Ethylene Glycol to kill an Adult. not to mention "god knows what other crap it has at that area"
Also, All coolant sold in the US today should have denatonium benzoate in it. Its a chemical that has this ultra, in-human bitter taste. Its not deadly. but they add that in to kill Ethylene Glycol's sweet taste. (so no animals or dumbasses will think they're drinking kool-aid. but if they have no taste buds thats another story ...)
Old Dec 3, 2008 | 11:09 AM
Rotard's Avatar
Registered Rotard
Soda pop's a fluid...
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
XianUnix
Sep 29, 2015 03:48 PM
DG07
Sep 28, 2015 10:58 AM
