ac compressor, not coming on?
Old Nov 29, 2008 | 02:31 PM
rotopunk's Avatar
Exclamation ac compressor, not coming on?
Hello everyone, i hope you guys had a great thanksgiving. We had an 84 degree thankgiving day here in houston, and i noticed that one i turned on my ac, the air wasnt cooling. I then noticed that the compressor was not kicking on. No click or slight strain when as it would normally do. Has anybody here had this type of problem? Could it be a fuse or something? My car is a 2005 model , Ti gray and I have been the only owner. (well out of warrenty with about 68,000 miles)
Any input on this would be appreciated .
Old Nov 29, 2008 | 02:34 PM
StealthTL's Avatar
Metatron
Check the DIY thread on repairing the a/c control - see if the symptoms match.....
S
Old Nov 29, 2008 | 02:49 PM
rotopunk's Avatar
I couldnt find anything on DIY other than reprograming the controller, see its not that its blowing only hot air, its that the compressor is not coming on. So all i am getting is the fans.
Old Nov 29, 2008 | 03:16 PM
amstarvid's Avatar
ZM ZM X 8
I had my heater control unit go out 2 years ago - granted it was winter and I couldn't get the heat to come on, but I believe the AC wouldn't come on either. It was replaced under warranty.
Old Nov 29, 2008 | 03:20 PM
rotopunk's Avatar
the heater works fine,
Old Nov 29, 2008 | 03:23 PM
amstarvid's Avatar
ZM ZM X 8
bummer...I am officially no help then...good luck
Old Nov 29, 2008 | 03:59 PM
StealthTL's Avatar
Metatron
Try this -
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-no-heat-repair-heater-control-158200/
Also, check the fan clutch fuse, it has it's own in the front fusebox, 10 amp.
S
Old Nov 29, 2008 | 06:01 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah check the fan clutch fuse....that would b my first look
Old Nov 30, 2008 | 11:59 AM
EDZRIDE's Avatar
2005 White GT
After all the electrical tests, check the freon level too.
Old Nov 30, 2008 | 05:50 PM
rotopunk's Avatar
I checked all the 10 amp fuses under the hood, i didnt see anything that said clutch fan.
How do you check the Freon?
Old Nov 30, 2008 | 06:00 PM
04RX8man's Avatar
unscrew a cap on the A/c lines.....i think the caps are like a grey on the stainless steel lines there are a few....and get a small screw driver and press on the "nipple" type thing....but uh stand back it might spray on u hahaha......
Old Nov 30, 2008 | 06:01 PM
StealthTL's Avatar
Metatron
If you checked 'em all then it's probably low freon.
The fuse is #22 bottom of middle row, marked 'a/c mag'
Take it to an a/c shop for a diagnosis - might just be low, $50.....
(and don't go poking random valves - if freon comes out you can be blinded easily, and what will a squirt of freon tell you anyway?)
S
Old Aug 9, 2014 | 05:05 PM
FazdaRX_8's Avatar
well I am bumping a old thread instead of starting a new one.
my ac clutch will not engage. things I have tested
Tested the temp ****, seems to be in working order with power and scan up trick
Freon levels are good I think
with the car off I supplied 12v to the ac unit and clutch engages (load click)
the a/c mag fuse looks fine
so I am left with sending signal to the unit is there anything that could have been unplug? I know the signal wire is inside the power harness, the other end is? maybe the wite connector that goes into the fuse box?
any ideas would be greatly appreciated.
Old Aug 9, 2014 | 08:27 PM
logalinipoo's Avatar
Driving my unreliable rx8
Does the clutch kick on when you first turn on the ac then go off quickly?
It is most likely low fluid or a bad/unplugged pressure switch. It is a small risk to your compressor. If you really think the fluid is good then jump the clutch and let the car idle. Ac on high with the windows open and recirc off. Record the outside temp and the air temp in your vents then post them and ill check a pressure temp chart. The best way to check the system is a set of gauges not just the elchepo single gauge you get at autozone. The single gauge comes with a can of 134 and will at least tell you if the system pressure is low. That is while you have the system running.
Old Sep 23, 2014 | 04:11 PM
lasb1230's Avatar
Hi, I have the same problem in my car, did you fix it?? Thanks
Old Sep 23, 2014 | 04:28 PM
Bryantrx8's Avatar
i need help with my rx8 my car is turning off when I make a complete stop everything and my mechanic says that my rotary is mess up now and that I have to throw away the car or get a new engine is this true ?
Old Sep 23, 2014 | 04:33 PM
Bryantrx8's Avatar
NJ i think its my compression :[
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
