Just checked the oil...
Old Nov 28, 2008 | 11:23 AM
jonr-'s Avatar
When I got the oil checker up, it was covered with a brown milkshake - like foam..
what is that??
what does it mean..?
Old Nov 28, 2008 | 11:25 AM
Silver06's Avatar
Zoom Zoom....
It means that you haven't searched the forums before you started a new thread.....
This is a normal condition.
Old Nov 28, 2008 | 11:28 AM
Silver06's Avatar
Zoom Zoom....
To be a little clearer (and nicer) to the Original Poster....
There is a Mazda TSB describing the problem, and giving a solution
http://www.finishlineperformance.com...50-06-1664.pdf
Old Nov 28, 2008 | 11:32 AM
jonr-'s Avatar
thanks.
I was a little bit worried, and I didnt know what exactly to search for. my bad.
Old Nov 28, 2008 | 01:43 PM
kersh4w's Avatar
Hit & Run Magnet
is this number 1 for this year?
Old Nov 28, 2008 | 07:20 PM
no,
i think we are in the low teens. but who is counting..
Old Nov 29, 2008 | 09:24 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah there has been quite a few already....the search button is in the top right of the page by the way but if u still can't find it I will explain it......
When it is cold outside and your engine gets hot from driving the oil gets so hot compared to the outside temp causing condensation(which is water) in the oil so when you pull the dipstick out there is some "foam" on it just wipe it a few times and it should clear up....
now if you change your oil and it's all milky you have a prob but i've never heard of that unless there is a coolant leak into the combustion chamber
LB2739
Jul 9, 2019 02:25 AM
Danield97
Oct 10, 2015 05:58 PM
Forevermore
Sep 20, 2015 01:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
Irvinb16
Sep 11, 2015 10:27 PM
