Oil Light On
Old Nov 28, 2008 | 11:03 AM
tamz273's Avatar
Oil Light On
Hey guys,
I recently got my car serviced (fully) at the dealer about a month ago... Yesterday my oil light came on. I turned my car off and back on and it went off. A few minutes later it came back on. Again, off/on and it went away and hasnt come back on since... My pressure gauge hasnt moved from where it usually sits, and everything seems normal in the car...
What is the reason for the light going on?
Should I top off the oil?
Old Nov 28, 2008 | 11:07 AM
hey tam:
Step 1: check the oil level. Make sure you're on a flat surface and see where it sits.
#2: our Oil pressure gauge is actually a "dummy gauge". It never moves from it's pre-determined spot if the system has any pressure at all. ie; if your car is on, it'll go to the same spot every time. Some of us have installed functional oil pressure gauges due to this. (not necessary for most)
Is there any oil leak?
Old Nov 28, 2008 | 11:09 AM
Silver06's Avatar
Zoom Zoom....
Originally Posted by tamz273
Hey guys,
For goodness sake, CHECK YOUR OIL!!!!
F.Y.I., the oil pressure 'guage' is not really functional (it always reads the same, regardless of the actual oil pressure).
The low oil sensor has seen some failures, but should never be relied on to decide when to add oil to the car (as it is a pressure-based sensor, not a true level sensor).
Check your oil per the Mazda recommendations...
Car on level ground,
shut off,
wait 5 minutes for oil to get to the sump,
keep the dipstick between 3/4 full and full,
don't overfill
Check the oil every second fillup.
Silver06's Avatar
Zoom Zoom....
Dammit Jedi... LOL.
Old Nov 28, 2008 | 11:10 AM
too slow you are Silver.
Old Nov 28, 2008 | 11:19 AM
tamz273's Avatar
haha wow! never got a response that quick! :P thanks guys!
but to answer ur questions, i dont think theres an oil leak anywhere... i smelt some burning clutch the other day but thats only cuz i was driving like an idiot and drifting every turn i took and every light i stopped at... (one of those days you wanna make the best out of ur car) Ill check my oil lever next time im parked!
Old Nov 28, 2008 | 11:21 AM
unless you're posting from your car, why not check it before you leave whereever you are now?
IF that light came on, that means your car is very low on oil and probably shouldn't be driven hard.
Old Nov 28, 2008 | 11:26 AM
tamz273's Avatar
it hasnt come on today or all of last night... and the reason im not checking it now is cuz my car is parked in valet, so to get it they drive it out(always scares me that they might flood it)... so next time i go sumwhere and park, ill let it cool down and have a look...
Old Nov 28, 2008 | 11:29 AM
sounds good; keep us posted.
P.S. Valet parking scares me. (flashbacks of Ferris Bueller's Day Off)
Old Nov 29, 2008 | 02:24 AM
tamz273's Avatar
o they scare ME... specially becasue the turn teh car on, drive it for less than a minute, part it and turn it back off... (the best way to flood an RX8)...
Old Nov 29, 2008 | 11:40 AM
toneskii707's Avatar
suck my smog
Hahaha lol that's why I never do valet parking!
Old Nov 29, 2008 | 05:14 PM
Old Rotor's Avatar
When you go to check it bring Two quarts of your favorite oil. The Rotary engine is Oil injected so it better be burning oil or your in trouble. It will burn according to how hard it is driven. The dip stick has 1.8 quarts from "H" to "L" and the oil lite will come on near or below the "L" so you might need two quarts to fill it. We have seen more then one person on here that did not read there manual and burn up the engine. Please let us know what you find.
Old Nov 29, 2008 | 06:17 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah yo are supposed to check your oil every other fuel fill up....u better check it asap and do not beat on it until u check it...u don't want to burn up the motor
Old Nov 29, 2008 | 06:40 PM
tamz273's Avatar
o wow, good to know... well the light DID come back on today wen i stepped hard on the car (raced a Toureg V8) and right after i let the car cool and I checked the level... it was halfway up that "indicator" so to speak... The bottom part of the oil stick thats like a meter, the oil was halfway through that... Im filling her up in a bit with some more oil cuz im assuming thats the problem.. am I correct?
Old Nov 29, 2008 | 09:12 PM
greg985's Avatar
The 337
AweS0me dawg!!! Did u p0nerize hiz azz?!!?!?!?
Old Nov 29, 2008 | 09:18 PM
street racing you say???
Old Nov 30, 2008 | 02:53 AM
tamz273's Avatar
hahaha, i did take him, but not my much... was pretty impressed with how he kept up, shocked me... but back to my prooooblem... just fill her up u say?
Old Nov 30, 2008 | 09:56 AM
04RX8man's Avatar
yeah fill it up to the top of the "indicator" line do not overfill if you're about half way down that's about a qt. but try a half first then check then fill up the rest of the way......
Oh and you meant you raced the Toureg at the "track" not on the street because this forum does not condone street racing and you may b banned for it....however like u did just on the track is fine!!! lol
Old Nov 30, 2008 | 11:26 AM
NotAPreppie's Avatar
What am I doing here?
This was at a drag strip, right?
Old Nov 30, 2008 | 12:33 PM
I8U's Avatar
I8U
^Does it matter...the OP is still an R-tard for knowing the basics of the car. Hell even my 10 yo cousin knows to check the oil if the oil light comes on...WTF!
Old Nov 30, 2008 | 06:47 PM
tamz273's Avatar
yes at the strip offcourse!!
Skyl3r
Dec 2, 2019 04:51 PM
drebbrnator
Dec 27, 2018 07:02 PM
talonhart2
Aug 26, 2015 04:14 PM
mesaboogie
Aug 7, 2015 10:48 AM
