Donuts with the 8
Old Nov 27, 2008 | 01:49 PM
bvisser's Avatar
Donuts with the 8
So, snow has been falling around my place in canada, and I'm starting to see some empty parking lots ripe for doing some donuts.
I've always had a FWD in the past, and the technique was simple. Drive in reverse up to a certain speed and crank the wheel, then, WEEEEE!
But I was hoping someone could share some sweet RWD donut techniques with me .
Is there more to it then just hitting the gas and turning left at about 15-20 km/h's? I was doing this and ended up mostly just sliding to the right or sliding to the left.
(Yes, DSC was off (not disabled, but off) before anyone asks)
- Brando
Old Nov 27, 2008 | 02:07 PM
tubingchamp's Avatar
What mawd bug?
Youll need to DISABLE DSC, by just pushing the button you disable TCS (Traction) so you can break the tires loose, but the stability control tries to help you out abit.
Also, doughnuts are easier from a standstill. Crank it, THEN accelerate.
Old Nov 27, 2008 | 02:26 PM
kersh4w's Avatar
Hit & Run Magnet
hold dsc down for 7 seconds.
turn wheel, smash the gas. spin!
Old Nov 27, 2008 | 02:48 PM
bvisser's Avatar
whe hew!
Old Nov 27, 2008 | 04:05 PM
RACESHARK's Avatar
dsc off,rrrm rrrm,weee
Old Nov 27, 2008 | 04:14 PM
I got your donuts and RX-8 right HERE!!!
Old Nov 27, 2008 | 04:58 PM
SayNoToPistons's Avatar
Wheels, not rims!!
Interior swapped base AT rx8?
Old Nov 27, 2008 | 09:58 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah disable it then try to go from a standstill crank wheel and romp the gas....if you want to try to drift then go into a doughnut you need a little "drive with the accelerator" technique but that just takes practice....drive straight turn wheel and mash the gas get it sideway and either countersteer to stay drifting or keep it turned and go into a d-nut......good luck that's the reason y i miss living where it snows.....
Old Nov 27, 2008 | 10:43 PM
kersh4w's Avatar
Hit & Run Magnet
whose rx8 is that? i cant believe they let people put donuts all over it. lol.
Old Nov 27, 2008 | 10:54 PM
I know but I'm not tellin....
Old Nov 27, 2008 | 11:17 PM
04RX8man's Avatar
it's not mine i do know that
Old Nov 28, 2008 | 07:24 AM
Renesis07's Avatar
Vtak just kicked in yo!!
- Brando
lol, just turn your wheels and go.........
Old Nov 28, 2008 | 08:46 AM
laythor's Avatar
I zoom therefore I am.
doing donuts = fail
is your honda in the shop?
Old Nov 28, 2008 | 08:53 AM
chrism's Avatar
Misfit Moderator TnC
another one bites the dust
Old Nov 28, 2008 | 09:20 AM
bvisser's Avatar
doing donuts = fail
Says the guy from San Jose lol...
Plus I don't know of too many RWD Honda's (not that I would care if there were).
Old Nov 28, 2008 | 01:32 PM
kersh4w's Avatar
Hit & Run Magnet
i've seen a rwd drag civic.
Old Nov 28, 2008 | 01:41 PM
TopGear8's Avatar
mkuhnracing.com
Someone should have learned how to drive before buying a RWD car...
Old Nov 28, 2008 | 06:27 PM
CyberPitz's Avatar
Huge hole is huge
Sure, it's a simple idea to MOST of us, but that's like someone asking how to powerstall and getting the same answers!
At least he has the answer, just needs to do it and get videos!
Old Nov 28, 2008 | 06:57 PM
mulkio's Avatar
Under-prepared
I picked up a dozen donuts in the church parking lot on the way to thanksgiving dinner....................
Old Nov 28, 2008 | 07:15 PM
PSTNLSS's Avatar
The Former PSNTLSS
So RX8 owners run on Dunkin'?
Old Nov 28, 2008 | 07:20 PM
CyberPitz's Avatar
Huge hole is huge
If you put Dunkin' in there, you are just asking for blown Apex Seals.
I like Daylight Donuts, they do the job perfectly.
Old Nov 28, 2008 | 07:21 PM
PSTNLSS's Avatar
The Former PSNTLSS
I actually believe they are entenmann's donuts
Old Nov 28, 2008 | 08:58 PM
Renesis07's Avatar
Wait! Our cars have enough torque to pull of a successful 'donut'????
Old Nov 29, 2008 | 03:15 AM
kersh4w's Avatar
Hit & Run Magnet
only if you do it in the twisties!
Old Nov 29, 2008 | 07:41 AM
luckygrrl's Avatar
1.3 liter piston eater
LOL my thoughts exactly!
