help battery died and car won't stay started
Old Nov 27, 2008 | 11:15 AM
Hesselrode's Avatar
US Navy Rotary Enthusiast
everytime i take my car to someone for something they always seem to run the battery down to the point of absolute nothing. everytime i jump it it seems like it doesn't want to stay started only if choke is on will it idle then after the choke is off the car dies, it doesn't idle right. i have fixed this before not knowing how and now i can't fix this.. i have read the errors and it is only the o2 sensor because the cat is not there. can someone help me out? it is drivable but when i come to a stop either i have to give it a little gas to keep it running or it dies on me.
Old Nov 27, 2008 | 11:54 AM
nuke0907's Avatar
Never Blend In
happened to me as well. check your ignition coils.
Old Nov 28, 2008 | 01:11 PM
Kaypee's Avatar
This happened after installing my radio... I disconnected the battery for about 2 or 3 hours and it behaved just as yours did... I drove it for about an hour and it was still doing it... so I just stopped and let it just idle for about 10-15 min... that seemed to fix it. I am not sure it's the same problem but mine would die after revving or just normal driving after coming to a stop but would stay on with a very rough idle if I just let it sit.
Old Nov 28, 2008 | 01:15 PM
Silver06's Avatar
Zoom Zoom....
Perhaps the Engine computer just relearning things...
Old Nov 28, 2008 | 07:21 PM
it should not be dieing, but it will idle odd for several drive cycles till the ecu settles down.
Old Nov 28, 2008 | 11:07 PM
Hesselrode's Avatar
really? stupid most advanced ecu.. lol how long i have drivin it for abot three to four hours now or longer and it still does it after about a week
Old Nov 29, 2008 | 01:08 AM
wow,
it is drive cycles. i will not bother to explain that..
this has been a problem for a week yet you posted yesterday? i call fail..
i would read the owners manual first. then go to the dealer and see if they have a clue how to help you..
good luck my friend/ amf.
Old Nov 29, 2008 | 05:39 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
same thing happened to me and i found out that my alternator was busted. bring it into the dealer if you have warranty because they replaced mine for free.
Old Nov 29, 2008 | 02:08 PM
Hesselrode's Avatar
okay.. the only reason i waited so long to post is because i took the liberty to try and fix it myself and figure it out.. i checked the alternator about three to four days ago and the battery and they are both good.. and if it is drive cycles i have driven it about a total of 15-20 times with a total of about five hours maybe more.
Old Nov 29, 2008 | 08:51 PM
if it is still stalling this is what you check
vacuum leak
loose spark plug or plugs
loose spark plug wire or wires
bad spark plug or plugs
bad coil or coils
bad battery connections
bad fuel pump
Old Mar 20, 2009 | 09:06 AM
Hesselrode's Avatar
okay so an update..
I changed the spark plugs.. didn't fix it..
I changed the coils.. didn't fix it..
going to try wires next and then altenator i guess....
Old Mar 23, 2009 | 06:08 PM
Hesselrode's Avatar
another update... took apart air filter and intake hose and throttle body cleaned up and put back together... note i didn't clean air filter or maf sensor... now idles better than before i bought the car...
Old Apr 5, 2009 | 10:17 PM
stet on 20"s's Avatar
good input, i'm having the same problem.
Wantingtoknow
Dec 15, 2016 02:25 PM
marc2820
Jul 26, 2015 10:47 PM
harithac
Jul 25, 2015 04:21 PM
T_Mags
Jul 24, 2015 11:29 AM
Kangarhew
Jul 18, 2015 08:27 PM
