View Full Version : catless midpipe = CEL?
AE92
11-24-2008, 12:34 PM
so i have a cat back system now buit i want a catless midpipe. if i just install it as is i would get a cel correct? so how would i go about clearing the CEL and being able to run the midpipe without a CEL?
Socket7
11-24-2008, 01:02 PM
put electrical tape over it. Or search the forums for an accessport or spark plug spacer.
Silver06
11-24-2008, 01:16 PM
Yes you will get a CEL.
The Cobb AccessPort (using a MazdaManiac map) will mask emmissions cel's ($695).
There are "MIL Eliminators" for sale all over the Interwebs (or you can make your own from Radio Shack). What they do is use a capacitor and resistor (replacing the Rear O2 sensor) to provide a steady voltage to fool the computer. From what I've read here, they are not very successful on the RX-8. The problem seems to be that the ECU expects different voltages as the car warms up - and throws a code if the voltage is constant.
04RX8man
11-24-2008, 01:30 PM
yes def a CEL the only way i know is like above is get the accessport
AE92
11-24-2008, 02:02 PM
what would the spark plug spacer do?
Silver06
11-24-2008, 02:08 PM
A spark plug spacer is an extension that moves the rear O2 sensor out of the flow of exhaust gasses.
Note that our rear O2 sensor is a device that transmits varying voltage to the ECU based on the oxygen content of the exhaust stream. If you move the sensor the *right* distance, then it will transfer different voltages from its normal location. It's getting this distance *right* that is the challenge.
dozer
11-24-2008, 02:25 PM
i installed a midpipe on mine this weekend...NO cel
Big Money Pit
11-24-2008, 03:00 PM
you just wait.
quazmosis
11-24-2008, 03:39 PM
I had a midpipe on for quite sometime and never got a CEL. It was the Agency Power midpipe. I took it off because it was insane loud.
Jon316G
11-24-2008, 04:45 PM
Give it a few drive cycles. Mine lasted a couple days without a CEL (both the AP and MazSport midpipe).
But few were lucky and never received one.
Razz1
Well there you.. isane loud and ticket or Cel.
MazdaManiac
11-24-2008, 08:45 PM
'04s often don't get CAT efficiency CELs.
