i need help
Old Nov 24, 2008 | 11:13 AM
eugeneweyker's Avatar
i need help
i need help i got this and i do not know much about the ecs system does this steering wheel turn with key off and with the key on engine off
Last edited by eugeneweyker; Nov 24, 2008 at 11:14 AM. Reason: need to adjust spelling
dillsrotary's Avatar
jersey fresh
{scratches eyes}
Old Nov 24, 2008 | 11:14 AM
dshiznit1489's Avatar
Formerly Polak Graphics
wat.
Old Nov 24, 2008 | 11:17 AM
DarkLord7854's Avatar
Software Engineer
I think he means, can you turn the wheel if the engine is off, or if the engine is off but the key is in.
The answer to what I translated is: Power steering only works when engine is on, so answer is no, you need to turn engine on. Says so in the user manual.
Old Nov 24, 2008 | 12:02 PM
8is>enuff's Avatar
Bland
^^ This is AFTER the edit?
I was going to help but I still can't make sense of your post, so I'm going to add in punctuation as I see fit and then answer.
I need help. I got this, and I do not. Know much about the ecs system does the steering wheel? Turn with key. Off and with the key on engine off.
Your frustration is understandable. The steering wheel’s knowledge of the ecs system is limited at best. Yes, I too turn with keys sometimes (but I rarely post about it on here - it's pretty common). Regarding off and with the key on engine off, in this instance the steering wheel is somewhat more familiar with the ecs than, say, in the instance of off and the key off engine on or on with the key off engine off.
I hope this helps.
Old Nov 24, 2008 | 12:12 PM
Software Engineer
I hope this helps.
Wut?
Old Nov 24, 2008 | 12:17 PM
04RX8man's Avatar
Rotary Powered Countryboy
yes i'm a little confused......uh to steer the car the best have car started.....
Old Nov 24, 2008 | 12:18 PM
Marklar's Avatar
eugeneweyker, why would you have to ask this question if you actually had the key? Is the 8 in question *cough* yours? And why do you suddenly "need help" with this to the point that you created an account just to ask this question?
Oh, and to answer your question, if you try to turn the wheel without the key in, the doors lock and the Homelink system calls the police.
Old Nov 24, 2008 | 12:34 PM
what the F*** is this world coming to? I wake up and read this and just want to kill people! I hope this is a f***in joke...
Old Nov 24, 2008 | 12:41 PM
Silver06's Avatar
Zoom Zoom....
I hope this helps.
That was Brilliant!
I'll try the same thing with certain emails at work!
Old Nov 24, 2008 | 12:57 PM
Socket7's Avatar
ಠ_ಠ
Old Nov 25, 2008 | 11:12 AM
let me me say this, I just bought this car not running, and i had a question? With the engine off key on, i could not get this RX8 to steer at all I was just wondering if that was normal ,or not.
Old Nov 25, 2008 | 11:18 AM
greg985's Avatar
The 337
Question...why would you need to steer the car while it is off?
Old Nov 25, 2008 | 11:19 AM
to get the car inside to work work on it
Old Nov 25, 2008 | 11:22 AM
greg985's Avatar
The 337
just turn it on drive it inside and then quickly turn it off before it warms up and you will be good. According to your post you want to do double work, so you can do your planned work and de-flooding work
Old Nov 25, 2008 | 11:23 AM
the engine is not flooded it is lock up
Old Nov 25, 2008 | 11:58 AM
jersey fresh
your steering wheel is locked, try turning the wheel really hard while turning the key.
Old Nov 25, 2008 | 12:02 PM
StealthTL's Avatar
Metatron
Let me have a crack at this....
Your steering is locked, not the engine?
The steering is electric, if the battery is flat the steering will be very heavy without the engine running.
S
