Transmission fluid
Old Nov 23, 2008 | 01:34 PM
BladerunnerChucky's Avatar
Transmission fluid
Hi, guys
I just hit 29,000 miles and had my dealer change my transmission oil.
As soon as I drove off the lot, I noticed that shifting is harder and not as smooth as my previous stock fluid.
I checked my receipt and looks like they used Motorcraft 75w90 which is indicated for their Ford 4x4 vehicles. Dealer is Ford/Mazda
Should I be concerned about my transmission and contact the dealer? Should I give more time? Am I just being ****?
Any input would be appreciated.
Old Nov 23, 2008 | 01:38 PM
zoom44's Avatar
read your manual?
Old Nov 25, 2008 | 09:28 AM
otakurx's Avatar
Rotorheaded Geek
I had a similar thing happen to me, seems to be an issue with certain GL-5 fluids. Happened in my RX-7 too as a solution I picked up GL-4 fluid and Syncro-Mesh (normally for GM vehicles I believe) and found that it cleans up the shifting beautifully. Soon as the rain stops up here I am putting that mix in the 8 and can let everyone know how that goes.
Old Nov 25, 2008 | 12:48 PM
04RX8man's Avatar
Rotary Powered Countryboy
I thought that 75-90 or 80-90 is what we were supposed to use?
Old Nov 25, 2008 | 08:22 PM
Make sure it is GL4
Old Nov 26, 2008 | 12:31 AM
Fullthrottle's Avatar
so tranny fluid for a manual should be GL4 ? just wondering because im planning on changing mine as well
Old Nov 26, 2008 | 12:38 AM
636's Avatar
636
Rice Police
Yeah it has to be a GL4 , GL5 eats away the synchros. I think its made of copper thats why. I think a safe bet is to buy the MT-90 from redline (its a 75w-90 GL4) , for the differential u can use a GL5 fluid i believe...
Old Nov 26, 2008 | 02:47 AM
ok so GL4 for tranny and GL5 for the diff correct me if im wrong please
Old Nov 26, 2008 | 08:08 AM
otakurx's Avatar
Rotorheaded Geek
Ya when the shop did mine, they put GL-5 in because that's what the computers say to use. So watch out.
Old Nov 26, 2008 | 09:41 AM
dozer's Avatar
on his 3rd rx8
LOL!!!!!!! i like 636s siggy...
Old Nov 26, 2008 | 11:24 AM
fastlaneracing's Avatar
Rotor User
I use Honda's new updated S2000 transmission fluid.
Works so mutch better than Mazdas, no more harsh changing to 2 gear and reverse.
Old Nov 26, 2008 | 11:32 AM
shaunv74's Avatar
Power!!
+1 they should use GL4 and it should be instantly noticeable if it's right or not. Bring it back and tell them to please use the Mazda OEM GL4 transmission fluid not the Ford 4x4 stuff.
Old Nov 26, 2008 | 11:44 AM
rotary.enthusiast's Avatar
The Local Idiot
Motorcraft has two 75W90 GL4 fluids, one synthetic, one not. They do also make a 75W90 axle lubricant which is GL5.
More information needed... and BTW, it wouldn't surprise me if the non-synthetic Motorcraft 75W90 GL4 came in your car from the dealer.
Old Nov 26, 2008 | 11:54 AM
shaunv74's Avatar
Power!!
Good to know and very possible, but the shfiting should definitely not be worse if the put in the same GL4 as before. GL5 will make the shifting harder and possibly hurt his transmission.
Old Nov 26, 2008 | 12:22 PM
LionZoo's Avatar
road warrior
I thought the factory fill was a straight 90? I know they previously specced a straight 90 weight before it was amended to 75W90 being acceptable since straight 90s are very rare. In my opinion, my slightly crunchy 1-2 shift when cold is because I am using 75W90. I just shift slowly while the car is still warming up.
By the way, this is in the wrong section and we've already got many threads about this.
Old Nov 27, 2011 | 04:02 PM
cksnyder's Avatar
My transmission dip stick appeared milky with a dark oil, is this normal or could the coolant be leaking into my transmission? does anyone have any information about this? rx8 04
Old Nov 27, 2011 | 08:12 PM
jasonrxeight's Avatar
transmission dipstick?
you have an auto? or you mistaken it with engine oil which is indeed brown and can be milky if moisture in the engine.
Old Jan 8, 2012 | 07:44 AM
Hypnotk's Avatar
I have the same issue with my 04 automatic. Is the trans cooler in the radiator?
Old Jan 10, 2012 | 12:48 AM
ober's Avatar
does the honda s2000 fluid work that well? changing into second is so harsh in mine no matter how hard i try
Old Jan 10, 2012 | 11:49 AM
Marc_GS's Avatar
Hooked on go-fast crack
I've had major issues with fluids in my MT, with fluid meeting the spec. I recommend Redline MT90 fluid.
Curious to hear additional comments on this.
Old Jan 10, 2012 | 01:04 PM
Tamas's Avatar
Registered Lunatic
This is what I use in my tranny. Works great.
Old Jul 8, 2012 | 04:13 PM
boggey's Avatar
ep 90
Is 75w 90 the same as the old ep 90 ?
Old Jul 8, 2012 | 06:29 PM
usafrotard's Avatar
Ricer
Same stuff I use. I like it much better then redline.
Old Jul 8, 2012 | 07:39 PM
redline works fine for me.
Amsoil is good too.
Old Aug 2, 2013 | 03:35 PM
anthonyallred's Avatar
Im torn between the mt90 and amsoil.... Damnit.
