engine light
Old Nov 22, 2008 | 11:59 PM
Fullthrottle's Avatar
engine light
so i got on my car through second and third when all of a sudden my engine light started blinking at me thought to myself damn it whats this all about just got the car a week ago and its already yelling at me but after i drove it in lower rpm's the light turned off any ideas ?
when i got home i put it in the garage and popped the hood because recently my low coolant light was turning on at start up for a couple of seconds after it should have turned off so i checked the oil for the hell of it too and my oil is chocolate milk so i guess i found out where my coolants going could this also be the reason for my engine light ?
so looks like im going to the dealer for a reman engine
Old Nov 23, 2008 | 12:08 AM
mac11's Avatar
Rotary , eh?
You are probably getting condensation on the dipstick. Known issue.
The coolant sensors are also pretty sketchy. Add a couple oz if it makes you feel better.
Your flashing light was probably a random misfire and no big deal.
Old Nov 23, 2008 | 12:23 AM
deadphoenix52's Avatar
meh.
bad coolant sensor. known issue. warranty TSB
milky dipstick. known issue. no problem. warranty TSB
flashing CEL. misfire. youre fine
Old Nov 23, 2008 | 12:30 AM
coolant sensor covered under the 8 yr warranty cause im at 56k so im done with the bumper to bumper
and as for the misfire im about due for plugs, wires and coils right ?
Old Nov 23, 2008 | 12:36 AM
mac11's Avatar
Rotary , eh?
I would say you should be getting ready to put the 3rd set on the car.
Old Nov 23, 2008 | 12:50 AM
mac11's Avatar
Rotary , eh?
https://www.rx8club.com/series-i-tech-garage-22/fall-here-winter-coming-things-remember-about-your-rx-8-a-129198/
Old Nov 23, 2008 | 12:51 AM
i just got the car so im catching up on stuff right now
so changing plugs, wires and coils should solve my misfire and warranty should cover dip stick moisture
Old Nov 23, 2008 | 01:17 AM
The stickies in the tech section is a good place to start.
Old Nov 23, 2008 | 08:10 AM
04RX8man's Avatar
Rotary Powered Countryboy
yeah in PA it's that time where it's gettin cold etc (used to live in PA i know what it's like) so you will get some water in the oil becasue on condensation in the oil pan from the heat of the oil and it being so cold outside makes condensatioin....just check it a few times to get right of alot on the dipstick till you can read it....once summer/spring hits all that will b gone and won't have to worry about it...
However go to autozone to read the code for free and make sure it was a misfire....
Old Nov 23, 2008 | 11:33 AM
zoom44's Avatar
read the winter link in my sig
Old Nov 23, 2008 | 11:38 AM
mac11's Avatar
Rotary , eh?
I didn't pretty it up like you but that is the link I posted.
xAgyex
Jun 3, 2026 03:47 PM
ladnarf1
Apr 29, 2021 11:53 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
