Thunk/knocking noise
Old Nov 22, 2008 | 05:01 PM
asylum9's Avatar
I'm getting a thunking / knocking sound from somewhere in the rear end of the car and I'm not really sure what or where it's coming from. Its an 04 manual trans.
Last month I took my car in to get a PA state inspected before a trip.
I pick up the car and everything is good. Load up the car and head out. About 200 miles later I start to notice a knocking noise from the back end.
I never hear it when I'm on the throttle or on the brake. I mostly hear it when I'm coasting and turning like onto a side street but sometimes I can hear it coasting through a parking lot or a strieght line and it seems to be getting a little worse no that its only 20 degrees out.
It sounds like theres something in the trunk that bangs off the sides but theres nothing in there and it happens kinda rappid. If I apply gas or brakes I don't hear it.
Any ideas what is could be? Is there a bushing that commonly fails with these cars?
Old Nov 22, 2008 | 05:04 PM
alexanderiv99's Avatar
yes their is a recall on that...you need to get that checked ASAP
check the lower control i believe thats what the recall was on for some of the vehicles
Old Nov 22, 2008 | 05:15 PM
Rotr8's Avatar
whines all the way home
silly but stupid because its happened to me but may be a loose lug nut,,, Mine only knocked when I was coastin, it wasnt knocking when I was on the throttle because its under load...
and being a state inspection they may have removed the wheel to check the brakes...
Old Nov 22, 2008 | 07:51 PM
DOMINION's Avatar
I don't buy Kool-Aid
If you hear this knocking or thunking when you first move your car its norm. I heard on this board it was the ABS or pads coming off the rotors. Not shure its the samething you hear but hope this helps
Old Nov 22, 2008 | 10:06 PM
khronus79's Avatar
double check all your suspension related bolts, I had a similar noise and it only occurred at low speeds when going over small bumps or making tight turns. I had 3 loose bolts.
Old Feb 21, 2012 | 09:48 AM
BigAAA's Avatar
I just had the same problem. Noise from rear only when coasting. Turned out 3 of 5 lug nuts were loose. Hit a big pothole on a road trip, noise started 300 miles later. Tightened lug nuts and noise went away. Thanks.
Old Mar 5, 2012 | 05:43 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Bump.
Old Mar 5, 2012 | 07:12 PM
wrightcomputing's Avatar
Made in England
Jack the car up and check every nut that connects to the wheel hub the 5 wheel nuts and there are 4 bars that make up the multi link suspension check the other end of each bar that connects to the hub. When I do an alignment I often get a clunk noise after the suspension settles and need to tighten up the nuts again.
Old Mar 7, 2012 | 10:54 PM
gmoney's Avatar
1SIK8
I just had this similar problem........right after i took my car to Discount Tires the knocking noise is there. i saw the whole thing all they did was jack the car up take the tire off check it and put it back on. but ill check my lugnuts real quick........
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
neoksk
Sep 21, 2015 12:31 PM
