Engine Swap Auto to Manual
Old Nov 21, 2008 | 03:18 PM
mazda2004's Avatar
My auto engine is no good. I purchased a manual engine, which form the people I bought it from, All Import Salvage, they said the manual and automatic engines are the same, except the flywheel, they say all i need to do is put my flywheel on the manual and it will fit. it was all going good until i went to hook up the intake and on the manual there are 6 holes and the auto that was from my car there are only 4. it is a high output engine and mine was standard i do believe. There is also the manual are electronically controlled and mine were vacum. Is there any way to make this work for cheap? Is there some kind of adapter plate? I have contacted the people i bought it from and they are looking, anyone know anything that i can do?
Old Nov 21, 2008 | 03:21 PM
StealthTL's Avatar
Metatron
So you don't have the intake manifold from the 'new' block?
S
Old Nov 21, 2008 | 03:23 PM
Marklar's Avatar
Wow, that's not a good thing to learn the hard way. If they told you it would fit then they should either exchange it or give you a refund, seriously. They probably honestly didn't know about the extra ports, but it was their mistake really, though it would have been better if you'd have come here first instead of trusting them (hindsight is 20-20, I know).
Old Nov 21, 2008 | 03:29 PM
Silver06's Avatar
Zoom Zoom....
As you now know, The manual engines are 6 port and the '04 and '05 auto engines are 4 port.
When you find the 6 port intake (and probably a computer from an '06 to '08 auto) the engines should swap.
Old Nov 21, 2008 | 03:30 PM
zoom44's Avatar
take it back they were wrong
Old Nov 21, 2008 | 03:47 PM
CTrx8's Avatar
space for rent
rotary resurrection has done the swap but this is not something you can do cheap. take it back and make sure they either refund it or swap.
Old Nov 21, 2008 | 03:52 PM
GaMEChld's Avatar
Registered Noob
sounds like a plan to me. I don't know how much the intake manifold and computer will run you though. Maybe contact Mazmart to get an idea.
Old Nov 21, 2008 | 04:07 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah take it back and tell them that they messed it up and either get a 6port with the intake manifold computer and everything ready togo to get another 4 port....but a ? y are you not just taking it to the dealer under warranty? It's covered for 8 years and or 100,000 miles unless u were highly modified and voided the warranty
Old Nov 21, 2008 | 06:52 PM
daisuke's Avatar
rotorized!!!
are you trying to put the manual rated engine on the 4 speed automatic transmission?
I'm sure there is a reason that the engine is de-rated for the automatic, put on the higher powered engine and you might blow the tranny... right?
Old Nov 21, 2008 | 07:48 PM
Marklar's Avatar
Isn't the 4-speed auto supposed to be the strongest tranny? Can't claim to really know myself, just repeating what I've read.
Old Nov 22, 2008 | 03:03 AM
I GOT THIS, AND YOU ARE WHERE????
Old Nov 22, 2008 | 03:09 AM
ZumnRx8's Avatar
RX8 & RX7 owner
i heard peole pushing 300-400 hp turbo'ed on the tranny AT and not having a roblem...and yes AT trannys are suppose to be stonger, the diff may be a different story,
Old Nov 22, 2008 | 03:16 AM
really,
where have you heard that? links..
not a huge 300 to 400 on six speed.. i think of only three here that have done an auto.. i recall none of them doing over 300.
is the tranny the issue, not really! but it will fail before the rear diff.
Old Nov 22, 2008 | 03:20 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Originally Posted by swoope
really,
sorry no links, just words i heard floating around in the forum, and out of the thousands of posts ive read, i dont think ill be able to recall them. sorry.
Old Nov 22, 2008 | 03:24 AM
sorry,
those words are not floating around here on this forum. maybe another one?
Old Nov 22, 2008 | 03:26 AM
ZumnRx8's Avatar
RX8 & RX7 owner
it was this one.
Old Nov 22, 2008 | 03:32 AM
it was this one.
fail.
stop talking out of your ***.
read more. and the thousands of posts you have read. doubt it.. you have not been here that long.
the advice you gave in this thread is wrong.. but that is a pass as this thread is been covered several times.. can you find it?
now if you want to get into a pissing contest with me i am subscribed to over 6700 threads. that means i read a lot here.
lots off useful knowledge here. and sometimes bad advice and people posting stuff that is not close to true or proven..
pick the right choice.
Old Nov 22, 2008 | 03:50 AM
snowflakes's Avatar
.DriVeN.
fail.
YEAH!!!
DAMN RIGHT!!
Old Nov 22, 2008 | 07:42 AM
Renesis07's Avatar
Vtak just kicked in yo!!
wow, no offense to the OP but how could you not know there were two engines? Talking about failure to search....
Old Nov 23, 2008 | 11:38 AM
mazda2004's Avatar
Yea they are taking it back for a refund. I prolly should have asked here first but the company i bought it from ensured me that they were the same. if anyone is looking for the body on a 04 rx8 with a complete body kit and other stuff it is for sale for 4,500, the body only has 54,000 miles on it, heres the link,
http://www.modifiedcartrader.com/sea...ed&sortOrder=1
Old Nov 23, 2008 | 12:18 PM
ZumnRx8's Avatar
RX8 & RX7 owner
fail.
i havent been here that long? i used to have a different club name, i been here since 05,
Old Nov 23, 2008 | 03:55 PM
Renesis07's Avatar
What was your previous name then?
Old Nov 23, 2008 | 08:08 PM
RotaryResurrection's Avatar
kevin@rotaryresurrection
You could actually run the 6 port block in place of a 4 port. Just run the 6 port intake and leave the extra 2 ports closed (since the PCM cannot control them and you do not have enough fuel to feed them anyway). You'd have 2 injector ports to block off on the 6 port intake manifold, and reuse your 4 port fuel and wiring and such and it would run normally. The 2 secondary ports on a 4 port are about the same size as the 2 secondary (non auxiliary) ports on a 6 port block. They simply don't cut out the 6 port holes on the 4 port block. The ports are slightly different, but not enough to matter all that much.
Of course, if you can obtain the correct engine, then you should do that. IF you got an awesome deal on this one or if you could not return it, it could easily be made to work.
vapor2
Nov 3, 2020 03:38 PM
cschoeps
Aug 6, 2015 12:44 PM
xandersonx97
Aug 2, 2015 01:02 AM
marc2820
Jul 26, 2015 10:47 PM
