HELP! no headlights WTF?
Old Nov 20, 2008 | 09:04 PM
matthew121's Avatar
so today as I was leaving work I went to start my car and finish closing up, I started it and flipped the headlights on, then walked away ( and as most people do)
I just went to look back to admire my car and then out of no where both headlights just went out (at the exact same time) so I am thinking, **** ok, must be a fuse (since they both went off) walked back to the car, flipped the switch, and went back inside, came back out to the car, and popped the hood to locate the low beam fuse(s). pull them out, and they are fine.... so I am thinking okie must be the relay.
so I drive home, and pull it in the drive way, and pop the hood, do some more fuse investigating, and everything is fine. so I leave the hood popped walk over to the window and start flipping the headlight switch to see if I can hear the relay clicking, and I hear the first relay for the parking lights, then turn it more and yeap, still get a nice loud click from the headlight relay, so now I just dont know what to think, I do have aftermarket headlight bulbs ( this is not a HID car BTW), so tomorrow is friday, I work at 8:00, and IDK but I think if both lights went out at the same time it cant be the bulbs, but I think I would need to swap the stock ones back in before I can take it to the stealership for warranty (idk if aftermarket bulbs would void anything though) I get off at 2:00 so I would have to rush home change them and hope to be able to get my car up to the dealership intime for them to work on it and fix it before they close at 6 for the weekend.
can anyone think of anything it could be? for both lights to just go out at the exact same time? could it still be the relay, even if it is still clicking?
damn this is frustating....
thanks for your help, sorry for the bad grammar, long post, and bad punctuation.
Old Nov 21, 2008 | 07:07 AM
matthew121's Avatar
no one has any ideas?
Old Nov 21, 2008 | 07:13 AM
Jon316G's Avatar
Grasshopper
If the relay contacts are clicking, its less likely to be it.
But for troubleshooting purposes and to help narrow it down, you could swap relays with something else and see if it works.
Have you tried your stock bulbs in the headlights yet?
Old Nov 21, 2008 | 07:14 AM
Jon316G's Avatar
Grasshopper
Also, have you tried both your lows and highs?
Old Nov 21, 2008 | 03:21 PM
matthew121's Avatar
yea, so it was just the bulbs.... lol
thanks for the help though!
Shankapotamus3
Mar 14, 2021 03:53 PM
drlubell
Sep 26, 2015 11:58 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
