are my engine/diff mounts B/O? what else can go wrong...
Old Nov 20, 2008 | 03:05 PM
gh0st's Avatar
well, after my tranny failed for the third time, i noticed that each time i took it out and put it back in, that the large beam that connects it to the diff hangs lower and lower. now, it sits on top of the cross mebers which causes loud rattleing as you can imagine.
does this mean i have either/both bad engine and diff mounts? cant think of anything else that can cause this.
Old Nov 20, 2008 | 08:36 PM
Sovesky's Avatar
Sovesky
Well you are talking about the power plant frame right?(goes from tranny to diff) If it is hitting those brackets than you definetly have a bad mount somewhere. It could be both or one. You have to check them out. You have ne pics of your mounts or did you check them?
Old Nov 21, 2008 | 02:38 AM
you likely have a bad motor mount, and the ppf was not adjusted properly. which is more than likely why the transmission failed...
Old Nov 21, 2008 | 02:31 PM
gh0st's Avatar
oh caca
Old Nov 21, 2008 | 02:38 PM
yup, sounds like the mount must be toast.
Old Nov 21, 2008 | 09:45 PM
mac11's Avatar
Rotary , eh?
swoope FTW, maladjusted PPF is probably why the trans keeps failing.
Old Nov 21, 2008 | 09:46 PM
shaunv74's Avatar
Power!!
You need to bolt on the recessed side bolt to the diff from the PPF first to locate it properly.
Old Nov 21, 2008 | 10:15 PM
zoom44's Avatar
bold is the first thought i had
Old Nov 22, 2008 | 01:01 AM
wow,
15k posts you *****!!!
btw,
i am having front tranny seal failure @97k miles. with a proper ppf alignment.. but still shifts as new.
but motor drama is on the horizion.
05rx8mazda
Nov 28, 2015 09:42 AM
ShellDude
Oct 1, 2015 09:55 PM
pjwermuth
Sep 28, 2015 11:36 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
