View Full Version : electrical or mechanical.
eva02
11-20-2008, 01:45 AM
what's the difference or better? ill be installing a water temp gauge on the 8.
alz0rz
11-20-2008, 02:25 AM
electrical for sure.
you don't want a line going loose inside your cabin and hot coolant/oil spraying everywhere...
that and installing any mechanical gauge is a PITA.
nycgps
11-20-2008, 08:38 AM
the difference is
mechanical required u to connect the tube from the water source all the way into your cabin. So like alz0rz said, if the tube or the gauge leak for whatever reason, its going to be a total mess.
Electrical on the other hand, require just a sensor to be installed on the water source. much cleaner and electrical wire is ALWAYS thinner than a tube. making it easier to route it into your cabin.
Only good thing about mechanical is that its a bit cheaper.
I have electical Defi gauge installed. :)
eva02
11-20-2008, 03:12 PM
sweet ,thank's
04RX8man
11-20-2008, 07:16 PM
electrical for sure(if you didn't realize that from the above posters
Mazurfer
11-20-2008, 07:20 PM
the difference is
Most people will tell you that besides cheaper......a mechanical is more accurate, but I agree.......not at the expense of having hot coolant or oil all over the cabin! :icon_no2:
nycgps
11-20-2008, 11:53 PM
Yep ur right. Mechanical is more accurate, but not by too much :)
TrochoidMagic
11-21-2008, 07:31 PM
also agreed with more accuracy for mechanical gauges.
