help me about stereo display :( i pod connect
Old Nov 17, 2008 | 06:50 PM
nameissc's Avatar
hi
i bought the i pod connecter
and i remove 5 lines behind of stereo and pop off the audio system
and when i reconnected all the thing
after that, when i turn on power that stereo display is not work and
AC didn't work only light and wind control is work.
i did connect and disconnect many times but same thing i check fuse and connection. i think same wire is not work.
do i have to go deallership?
Old Nov 17, 2008 | 06:54 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
try to check if it is loose because i had that problem when i removed my stereo. you might have yanked it a bit when you put it back in or something. if not then go back tot he dealers
Shankapotamus3
Mar 14, 2021 03:53 PM
crimson809
Aug 14, 2016 10:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
archon
Oct 1, 2015 06:08 AM
