RX-8 Flamed blow out - Any ideas?
Old Nov 17, 2008 | 12:12 PM
Uncivilizedracer's Avatar
Turbo SR20deT Son!
Well here is the story i was coming from wedding rehearsal and getting ready to meet up with my folks for dinner, thought i would stop by the auto-wash (being lazy) and have the car looking super clean for papadeux, anyway i got out the auto-wash and the car started to hesistate and putter halfway down the service road i was unable to go over 40mph. So i pulled over and the car dies and the check engine light is flashing , hell i figure water got in the engine some how or the intake so i inspect everything and nothing checked the filter (bone dry) , what else could it be. So i waited a little while and and it cranked back up no issues ate then drove home got about 20 mins along and the same issue this time i saw **** flying out the back so i pulled over and there was this:
So i figured at this point the cat is gone even though the glow looks nice , had the code checked out and it said fould spark plug , im like ok ill buy that so i bought new plugs wires and spent saturday changing them out. Sweet now that im done and its darks reset the ECu light stayed on F-it , lets go ride, so my boy grabs his camera and we get about 30 mins out - no issues - go eat come back home and it started all over again so my boy notices something coming out the exhaust so he grabs the camera and this is what we got;
http://www.youtube.com/watch?v=EiY59NeYUng
http://www.youtube.com/watch?v=mYHt3_i9IBA
Now im screwed till i can get it to the dealer , mind you in the upside down vid i was only doing about 43mph trying to make it home cause we were on a bad road to get stuck on , felt like i was only running off one rotor.
Any ideas till i get it to the dealer ?
Old Nov 17, 2008 | 12:18 PM
greg985's Avatar
The 337
*waiting for the no0b to ask how he can get his car to do that*
Old Nov 17, 2008 | 12:20 PM
nvrfalter's Avatar
tonybob failpants
D0o0D h0w c4n i g3t My caR 2 d0 dAt hahaha
sucks. at least you got it taken care of and felt kinda cool for a little while haha
Old Nov 17, 2008 | 12:23 PM
greg985's Avatar
The 337
LAWLZ
whatever it is I am sure you need a new Cat now
Old Nov 17, 2008 | 12:26 PM
alnielsen's Avatar
Yep, looks like the cat is gone. But, you have another problem also. There is a lot of unburned fuel in the exhaust causing the flame. Check plugs and coils.
Old Nov 17, 2008 | 12:38 PM
Turbo SR20deT Son!
All that was checked and replaced ! Got to be something else .
Old Nov 17, 2008 | 12:40 PM
nvrfalter's Avatar
tonybob failpants
i thought you said on youtube you already got a midpipe or supercat or something
Old Nov 17, 2008 | 12:41 PM
RK's Avatar
RK
It's Not Easy Being Green
Trim might be off. Might want to try resetting your ECU. How's your gas mileage? Same/better/worse? If there's spent fuel you'll know it there.
Old Nov 17, 2008 | 12:43 PM
Turbo SR20deT Son!
Yeah i got one to replace it but its not going to do anygood if its still going to be heating up like that
Turbo SR20deT Son!
I did both resets and as soon as i try to crank it up the light is on again - gas mileage cant even be determinded right now as soon as the engine gets warm its hesistating and i cant go over 40mph
Old Nov 17, 2008 | 12:57 PM
Brettus's Avatar
Boosted Kiwi
one rotor is not firing perhaps ?
Old Nov 17, 2008 | 03:30 PM
greg985's Avatar
The 337
I doubt that would make the exhaust over heat that much though
Old Nov 17, 2008 | 03:48 PM
ShinkaTeen's Avatar
space reserved for shirt
i have an idea,... part it out... and sell me you clear corners :]....
worth a try.
Old Nov 17, 2008 | 03:57 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah cat is gone for sure....
Old Nov 17, 2008 | 03:58 PM
Brettus's Avatar
Boosted Kiwi
if one rotor was not firing you will get a whole lot of unburnt fuel in your exhaust so yes it would explain it .
Uncivilized :
This all started to happen after the car wash right ?
It has to be related to water in the electrics - perhaps one of the plugs going to a coil .
Old Nov 17, 2008 | 05:21 PM
alnielsen's Avatar
Make sure that the wires are fully on the spark plugs. It has happened to others.
And if the cat is plugged you won't be able to get revs. I have had 4 replaced on my car. A miss-firing engine will cook a cat.
Old Nov 17, 2008 | 11:59 PM
greg985's Avatar
The 337
+1
I had 3 bad coils and i had to limp to mazda, by the time I got there my exhaust had a good bit of smoke comming from it
Old Nov 18, 2008 | 01:24 AM
Uncivilized :
correct,
coil connections. not likely.
but plug wires loose or filled with water, yep.. or both..
car wash.. wow..
Old Nov 18, 2008 | 08:45 AM
greg985's Avatar
The 337
Reason #1,376 to not go to the auto car wash
Old Nov 24, 2008 | 04:45 PM
Turbo SR20deT Son!
Changed out the plugs and wires and the car wont start at all ****!!
Old Nov 24, 2008 | 05:06 PM
nvrfalter's Avatar
tonybob failpants
damn dude looks like youre having cat problems
Old Nov 25, 2008 | 09:41 AM
otakurx's Avatar
Rotorheaded Geek
Pix of the old plugs please. Can tell a lot by how they look. Will tell us how the engine is running internally.
Old Nov 26, 2008 | 12:27 PM
Turbo SR20deT Son!
ill take pics of them tonight , the cat is the last of my worries right now
Old Nov 26, 2008 | 12:38 PM
Rootski's Avatar
DGAF
Your cat is done, son. Looks like you had a misfire or two and the unburnt fuel lit off in the cat. The good news is, it should be covered under warranty. The better news is you could just buy a race pipe and never worry about it again.
uZu
Dec 30, 2015 12:35 PM
Nisaja
51
Sep 1, 2015 04:29 AM
MatthewRJ
Aug 5, 2015 11:29 AM
MolecularConcept
Jul 26, 2015 09:09 PM
