RX8 jumping around
Old Nov 14, 2008 | 12:15 PM
bomber's Avatar
RX8 jumping around
My lovely rx8 has just been for a 3 year service at mazda, sparks, diff oil, I was very impressed with there level of service and the car feels great. well I thought it did until I went to any empty car park to do some tricks. Basically if I want to spin up the back wheels the whole car jumps around really badly. It had never done this before the service.
Any ideas???
Old Nov 14, 2008 | 12:32 PM
alfy28's Avatar
When you mean by tricks. do you mean like making your car do a 360 flip to k grind. and also when you mean by jump. like as in a ollie?
btw never heard of these type of issues. but hopefully someone will be able to answer your problem.
Old Nov 14, 2008 | 01:06 PM
bomber's Avatar
ok. so if i set the revs high, dumped the clutch then the rear wheels dont spin up like they did...smoothly spinning up to cause tyre smoke. I know it sounds strange when your in the car it feel like the car is juming up and down and you have to stop, unlike before when it was smoking up big time.
Old Nov 14, 2008 | 01:11 PM
05rx8mazda's Avatar
B.I.G
turn off traction control
Old Nov 14, 2008 | 01:15 PM
bomber's Avatar
haha. sorry i hadn't made it clear that i have turned everything off, as always!!
Old Nov 14, 2008 | 01:28 PM
J8635621's Avatar
Pew Pew Pew
Have a fat kid sit in your trunk.
Old Nov 14, 2008 | 01:47 PM
bomber's Avatar
unfortunately we dont encourage child obesity where i live. I would like some good feed back on the problem i have
Old Nov 14, 2008 | 01:56 PM
Sell your car, get a new one.
Old Nov 14, 2008 | 01:58 PM
bose's Avatar
Reginald P. Billingsly
What else changed? Temps, tires, any suspension bits? Sounds like wheel hop is what your describing. Check in the rear under your car. See if the endlinks are connected and not broken. Aside from that I am not sure off the top of my noggin.
Old Nov 14, 2008 | 02:03 PM
416to212's Avatar
Utopia Taco Bell
Okay, time to get serious about playing...
You said you turned off traction control (full hold down button for 8 secs until you see 2 lights up on your dash) - at this point you can turn on DSC only after stopping and restarting the car.
The jumping around you are getting is actually called tire hop, and yes it is horrible in our cars, especially when our tires are cold and when you have things going on at low revs.
By parking lot tricks I usually mean donuts and powerslides.
When doing a donut, you have to dump the clutch at a high rpm to get the wheels to move beyond hopping to actually sliding. While performing the donut you also need to be reving high.
On a wet surface popping your clutch at 4000rpm is usually enough to get you through the hops. On a dry surface I dump at 6000 to get things going. While I'm spinning around I'm in between 4000rpm to 9000rpm and always in first gear.
The key to getting past the wheel hop is to keep the car well up in it's power band. Because we lack torque, it's the only way to do things. Rolling burnouts are really hard to do for this reason, but can be done with sensitive left foot braking and a heavy right foot.
No matter what I do I always get a bit of hopping at the beginning..
* sorry just reread the first post, I think I'm off the mark here...
Old Nov 14, 2008 | 02:09 PM
search for the term wheel hop.
Old Nov 14, 2008 | 02:13 PM
Renesis07's Avatar
Vtak just kicked in yo!!
You have a case of wheel hop, put a bunch of JL **** in your trunk like I did and itll go away.
Old Nov 14, 2008 | 03:18 PM
bomber's Avatar
temp has changed got real cold roound here just lately. bought the car in the summer.
Old Nov 14, 2008 | 03:22 PM
bomber's Avatar
yes i mean some donuts and drifting. Ok, some more power then? get pass the wheel hop. when you get to the hop you just feel like stopping!!
Old Nov 14, 2008 | 03:24 PM
Renesis07's Avatar
Feather the clutch out at 5-6K instead of dumping the clutch.
Old Nov 14, 2008 | 03:25 PM
J8635621's Avatar
Pew Pew Pew
Your tires are cold = less grippy? By fat kid, I meant some weight. Wheel hop is very, very common with this car.
Old Nov 14, 2008 | 03:39 PM
bomber's Avatar
maybe a bag of sand would help?
Old Nov 14, 2008 | 03:41 PM
bomber's Avatar
ok will try
Old Nov 14, 2008 | 03:42 PM
quazmosis's Avatar
Chode
I just wouldnt try doing donuts in your car.
Old Nov 14, 2008 | 03:55 PM
bomber's Avatar
Thanks for everybodys input. I will do some testing next week when i finish work.
Old Nov 14, 2008 | 04:49 PM
bomber's Avatar
My particular car, our the rx8 in general? Why?
Old Nov 17, 2008 | 03:41 PM
quazmosis's Avatar
Chode
I just don't see the point. Nothing against you personally or anyone.
Old Nov 17, 2008 | 04:05 PM
shaunv74's Avatar
Power!!
I believe he is looking to bring it back to the dealer as soon as possible to complain about a broken diff...
atmd
Aug 19, 2015 12:43 PM
T_Mags
Jul 24, 2015 11:29 AM
Kangarhew
Jul 18, 2015 08:27 PM
dmengel
Jul 18, 2015 09:35 AM
