clicking/ticking sound when cornering hard to the right
Old Nov 14, 2008 | 11:14 AM
wishboneracing's Avatar
Looking for other ideas of things to check....
-wheel bearings "seem" ok -- no play, feel smooth. How else to check?
-no rubbing - all stock rims etc
The sound is unnerving -- Need to fix this!!
TIA
Old Nov 14, 2008 | 11:27 AM
check your sway bars and bushings.
Endlinks okay?
Old Nov 14, 2008 | 11:30 AM
Silver06's Avatar
Zoom Zoom....
Good morning.
You've obviously thought to check the tightness and re-torque all suspension bolts - on both sides of the car.
Also be aware that there was a service notice on upping the torque on the front wheel nuts to solve a similar problem
There is now a further TSB 02-005-08:
Some customers may complain of an unusual noise from the front of the vehicle. The plastic insert connecting
the stabilizer control link ball joint to the control link may crack (1) and become separated (2).
check it here at Rosenthal Mazda's TSB site
Good luck, and Please update your results.
Old Nov 14, 2008 | 11:43 AM
Great and fast info, thank you!
The wheel/disk issue seems a likely culprit, found the TSB here:
http://www.finishlineperformance.com...2-04-1301b.pdf
It calls for higher torque on wheel nuts of 108lb-ft, plus cleaning up mounting surfaces.
Thanks again! will report back
nowakm99
Oct 9, 2015 07:10 AM
iphil
Sep 21, 2015 10:49 PM
Paul_Y
Sep 21, 2015 02:23 PM
mattymack
Sep 6, 2015 10:33 PM
blkswan
Sep 2, 2015 10:04 PM
