Just 1 Question
Old Nov 12, 2008 | 06:36 PM
crod189's Avatar
Just 1 Question
So I just bought my 8 about 3 weeks ago and whenever I'm starting up the car it seems that it takes longer then usual to start up. It kinda seems like it has a low battery but after it starts, it's perfectly fine. Is that normal?
Old Nov 12, 2008 | 06:49 PM
DarkLord7854's Avatar
Software Engineer
As in, it turns over a few times before catching?
Sometimes mine does that if it's a bit colder than usual in the morning
Old Nov 12, 2008 | 06:53 PM
Phi's Avatar
Phi
Phi
how cold is it outside? my car only does it when i warm it up in the morning its likes 40 degrees out.
Old Nov 12, 2008 | 06:54 PM
crod189's Avatar
yea it turns for at least 3-5 seconds. It usually does take longer in the mornings but it still does it during the afternoon when the car is already warmed up.
Old Nov 12, 2008 | 06:55 PM
crod189's Avatar
yea its about the same here in oregon. The thing is mine does it alot. Not just in the morning
Old Nov 12, 2008 | 06:57 PM
Phi's Avatar
Phi
Phi
what year is your 8 and miles?
Old Nov 12, 2008 | 06:58 PM
crod189's Avatar
Its on 04 with close to 35k miles.
Old Nov 12, 2008 | 07:03 PM
Old Rotor's Avatar
How old is your battery? Have you had the upgraded battery and starter put in(there was a "TSB")? You might want to check the water level in your battery, even tho they say no maintenance it might be down to the top of the plates. Have you changed your plugs yet? 35k is when it is due...
Old Nov 12, 2008 | 07:08 PM
crod189's Avatar
I really dont know how old my batter is but I'll check the water level when I get home and I have not put in the upgraded battery.
Old Nov 12, 2008 | 07:45 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah mine does that everyonce and a while too I would check the battery also...if it's still the original prob close to a new one soon Mine is an 04 and i'm about ready to replace it just so it does not leave me stranded somewhere
Old Nov 12, 2008 | 07:49 PM
crod189's Avatar
Okay! Thanks, appreciate the help.
Old Nov 12, 2008 | 07:50 PM
SideOfBacon's Avatar
sounds like battery may be going bad.. could also be gunked/dirty plugs and its taking a bit to fire.
Old Nov 12, 2008 | 08:39 PM
they have slow starters if its an 04
Old Nov 12, 2008 | 11:11 PM
greg985's Avatar
The 337
just got my battery relpaced about a week ago with the same symptoms
Old Nov 13, 2008 | 12:30 AM
hakuna matata!
i changed my coils a while back for the same symptoms.. along with random misfires..
my car would take 3-4 seconds to start up regardless if it was warm or cold out.. now it fires up within 1 second.
surprised noone else said it.. especially for an 04 with that many miles.. replace your plugs, coils, and wires anyway.
Old Nov 13, 2008 | 05:07 PM
crod189's Avatar
ok well yea i guess i'll do that. Everyone seems to say its my battery. But wouldnt a light come on if it was my batter? like telling me it was low or something?
Old Nov 13, 2008 | 05:24 PM
RX8Sinner's Avatar
Not always, and the nice thing about manual cars, if your battery does die, just push it and pop the clutch to start it.
But if its an 04, why not just do the basic replacements on it that most people seem to do? Coils, Plugs, Wires, battery.... Just do everything at once save yourself the hassle later on.
Then again I should do as I preach I have an 04 with 40k and i should probably do the same, i'm just lazy and broke.
Old Nov 13, 2008 | 09:47 PM
crod189's Avatar
haha yea im pretty much broke after buying this car too. ****** goin to school and working part time is hard work! Especially next year when i go to college haha.
I guess i'll start with the coils, plugs, wires, and battery once i get the chance too!
Old Nov 14, 2008 | 10:56 AM
CyberPitz's Avatar
Huge hole is huge
Make sure you have the updated battery and starter. More than likely the issue. When it gets cold, it takes maybe 1-1.5 seconds of cranking to fire up instead of right away when it's warmer out. I'd assume you have to check on bat/starter.
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
