Painting Calipers
Old Nov 9, 2008 | 05:17 PM
Jonathan11's Avatar
Pain Is Weakness
Painting Calipers
Hi, i was just wondering, I have seen a lot of threads were people have painted there calipers and wheel hub. Now my question is this i don't want to have to take apart the calipers nor the rotors....SOOOO can i just take off my wheel and paint the calipers and wheel hub?
Thank You
Old Nov 9, 2008 | 05:36 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yes......carefully.......with a brush of course.
Old Nov 9, 2008 | 05:52 PM
Jonathan11's Avatar
Pain Is Weakness
Thank you! Another question how long must i wait for the paint to fully dry? i dont have more than one jack at my house so i will be doing one wheel at a time.
Old Nov 9, 2008 | 06:15 PM
Mazurfer's Avatar
Depends on what you use and how carefully you can put the wheell back on without touching anything. Most dry pretty fast....I think I would wait one hour to put the wheel back on and you should know that most caliper paints will say not to drive for about 12-15 hours(I think).
Old Nov 9, 2008 | 06:21 PM
Jonathan11's Avatar
Pain Is Weakness
Sounds good to me thanks
Old Nov 10, 2008 | 06:44 AM
PBlue's Avatar
Dial P for Phantom
Rotor Hubs painted, Calipers painted. I actually took the rotors off the car and cleaned and taped off and painted them, so that the hubs are perfectly done and no paint got onto the braking surface. But i painted the calipers on the car while putting the rotors on, let dry for 15 mins before i reassembled them on the rotors. After i was done i waited about half an hour, went on a 10 minute test, did braking from 70-0 (not on purpose). They lasting great so far.
Wheels very dirty in first pic, normally the glossyness of the calipers and wheels are identical.
Washed and left wet, the rotor pad surface will slightly oxidize, but back to silver as soon as you hit the brakes, the purpose was to keep the rest of it looking good. And for a total cost of a couple bucks.
Old Nov 10, 2008 | 08:24 AM
Mazurfer's Avatar
And as you may know.............I said screw it and went with "new" rotors!
http://www.racingbrake.com/RX8_FRONT...p/2015-381.htm
Old Nov 10, 2008 | 08:38 AM
psonoda's Avatar
Less Weight = Better RX8
I painted my brakes with the brakes on the car. I wrote about it on my blog. Check it out and let me know what you think.
http://audiogearlab.com/rx8/2008/08/...brakes-please/
The brakes have been pressure washed since I painted them without any peeling or problems.
Old Nov 10, 2008 | 08:43 AM
Huey52's Avatar
Registered Zoom Zoomer
Of course make sure you thoroughly clean/degrease the surfaces to be painted (hub and calipers, Not rotors). Doesn't hurt to abrade with fine sandpaper as well to provide a better bonding surface. Basically what you would do to prep and paint any metal that will be exposed to the elements. Rust-oleum paint is plenty good enough.
Old Nov 10, 2008 | 08:44 AM
Huey52's Avatar
Excellent job and great wheels!
Old Nov 10, 2008 | 10:57 AM
pdxhak's Avatar
Official Post Whore
Thank You
You do not have to take anything a part. Jack up the car and take off the wheels.
You will need the following:
Jack
Jack stands
Brass brush
Brake cleaner
Tape
High Temp Brake Paint
Clear Coating
Patience
Depends of the brand of paint so be sure to look on the back of the can. I believe my paint required 24 hours.
If and when you paint them be sure to go with black
Old Nov 10, 2008 | 11:49 AM
Mazurfer's Avatar
Of course no matter what color you paint the calipers, I always recommend painting the dust shield as well.
Even if you leave the calipers and rotors on as I did, paint the dust shields(black).
Attached Thumbnails Painting Calipers-new_rims4.jpg   Painting Calipers-new_rims5.jpg   Painting Calipers-new_rims6.jpg
Old Nov 11, 2008 | 07:00 AM
PBlue's Avatar
Dial P for Phantom
Painting the shields would be nice, but mine have tons of spot corrosion, i didn't think about it until i was already mid installation, i needed to drive the car the next day, and they're cheap new and pretty hard to see. Eventually when i move again ill buy new ones.
Old Nov 11, 2008 | 05:19 PM
Jonathan11's Avatar
Pain Is Weakness
Well my buddy owns a shop hes going to do it for me for free. Im going to go ahead and paint the calpiers silver like the car and the hubs either black or silver not to sure yet
Old Nov 13, 2008 | 04:39 PM
Never L8's Avatar
Really nice job on the pictured cars. I'll have to do this when I get my new wheels. Did you guys order the paint of just get it from AutoZone, or the such? Thanks!
Old Nov 13, 2008 | 04:45 PM
RK's Avatar
RK
It's Not Easy Being Green
Originally Posted by pdxhak
God damnit I love your wheels. How the hell do you expect anyone to see your calipers when you have wheels that nice?
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
GK1707
Sep 27, 2015 07:33 PM
TheRedRotor
Sep 22, 2015 05:30 AM
