View Full Version : Amazing Roll Off Question
Nopstnz8
11-09-2008, 01:35 PM
Hey guys I just got this stuff to use to clean my tires and fenderwells. Anyways, I was wondering how to use it on the tires with worrying about it getting on my Volks which I recently waxed and don't want the wax removed. I am going to take the wheels off the car when I change brake pads most likely today, so I need to know how to cover the wheels from getting the roll off on them. Any advice would be appreciated. Thanks.
nuke0907
11-09-2008, 03:05 PM
painters tape?
EDZRIDE
11-12-2008, 04:46 PM
Measure the diameter of your wheel then find a store that sells plastic products(such as TAP Plastics in Sacramento). Have them cut a circle in your diameter out of 1/8" sheet and glue a handle in the center; voila, instant (and durable) spray shield!
Alucard
11-17-2008, 03:40 PM
what did you get?
Just and FYI, if you are using something on plastic (ie federwells) it may not be good on your tires... how bad are your tires that you need to clean them?
