italyhot21
11-07-2008, 11:17 AM
Hey guys im getting the cel P0456:banghead:
And its not the fuel cap i went 2 the dealer and bought a new cap...
reset the cel came up again after couple days...
i dont know what 2 do i dont wanna go 2 the dealer and spent alot of money...
i have some questions
Where is the Evap control System and evap purge and vent solenoid located?
Thank u all for the help...:
dshiznit1489
11-07-2008, 11:30 AM
Theres a TSB for it I think. The dealer can fix it for free as long as youre under warranty.
Old Rotor
11-07-2008, 11:49 AM
How many miles do you have and what year, please give us all the info you can on your car. I believe the smog is covered for eight years or eighty thousand miles. Here is the TSB on the gas cap which should have been free.
http://www.finishlineperformance.com/pdf/rx8/bulletin/01-026-07-1800.pdf
otakurx
11-07-2008, 11:56 AM
He says he already replaced the gas cap on the car and that didn't fix anything, granted it is probable but unlikely that he got a second bad gas cap but I would think there would have to be something else amiss here.
italyhot21
11-07-2008, 12:05 PM
The car is a 04 GT MT 56.000 miles....
There is a TSB for a VIN range with bad filler necks that cause an EVAP code. You might fall into that, although I remember it being for '05s. Other than that, it seems to me that you should go to the dealer. Best of luck.
04RX8man
11-07-2008, 05:15 PM
check all your vaccuum hoses on ur intake manifold and anywhere else something mights have gotten knocked off like to the oil filter etc and make sure everythign on the neck or ur fuel tank is ok
