blank information display
Old Nov 6, 2008 | 12:45 AM
Alfred Duncan's Avatar
Hello forum members,
I'm a first time rotary owner. Just purchased a 2004 model Rx8 - great car!!
Recently the information display went blank. The backlight is on, but no display. A/C works but the Stereo doesn't. Anyone encountered this before? How did you resolve the problem.
Anyone has step by step instructions for removing the consol to get behind the stereo check for any loose electrical leads?
thanks!
Old Nov 6, 2008 | 01:18 AM
slimjimrx8's Avatar
have you moved ur headunit out at all or attempted to?
Old Nov 6, 2008 | 01:21 AM
hakuna matata!
the faceplate itself has a bunch of terminal leads into the actual headunit behind it.. it may be possible the previous owner did a half assed job of putting it back together and now the terminals are not making contact correctly.
you might do a search in this forum..
https://www.rx8club.com/series-i-do-yourself-forum-73/
Old Nov 6, 2008 | 01:22 AM
slimjimrx8's Avatar
for similar problem
https://www.rx8club.com/series-i-interior-audio-electronics-24/blacked-out-display-151859/
if you want remove radio and inspect yourself and take pics if you still have problems
http://www.whatsmyip.org/ipodrx8/
Old Nov 6, 2008 | 02:33 AM
Keyten's Avatar
I had this happen before. Do you have an aftermarket system? One time I was careless and blew my stereo fuses when messing around with wires and some of my electrical equipment wasn't working. Luckily it was a simple 50 cent fix.
Old Nov 6, 2008 | 07:57 AM
luckygrrl's Avatar
1.3 liter piston eater
If the back light on the display is still on, my first guess would be that you have blown a fuse. The same thing happened to my friend's Audi after he installed a subwoofer. It should be a simple fix if that is the case.
Shankapotamus3
Mar 14, 2021 03:53 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
nadodave
Aug 28, 2019 05:55 AM
Turbonostic
Rotary Swaps
10
Sep 19, 2015 11:53 AM
