Intake PROBLEMS
Old Nov 2, 2008 | 05:47 PM
jefecito87's Avatar
Jefecito87
Intake PROBLEMS
hey i took the stock air box out of the car and i put a large filter onto it instead of the stock on and i will say it sounds amazing with the aftermarket one but when i turned it on i lost like a significant amount of power and it stalled and sputtered like crazy i had to put the stock box back in and the problem was fixed..... any thoughts it feels like some vacuum problem..... what u think?????
Old Nov 2, 2008 | 06:03 PM
expo1's Avatar
He's as bad as Can
I think you proved why the OEM airbox is really not that bad. What you did was turn the OEM cold air intake into a hack job hot air intake.
Old Nov 2, 2008 | 06:05 PM
because you totally fuxked it up.
You cant just put a big *** filter there and expect it to work.
Old Nov 2, 2008 | 06:10 PM
Spinning Sushi's Avatar
I <3 Sushi
Where did you put the MAF? I'm pretty sure you're running without a MAF since you took the OEM box out.
Old Nov 2, 2008 | 07:57 PM
jefecito87's Avatar
Jefecito87
mass air flow is still on i had the fitting and i had it put on and there was no leaks through the mass air flow i just want to know why it wouldnt work i copied it just like the ones i seen but i guess i was missing something
Old Nov 2, 2008 | 07:58 PM
jefecito87's Avatar
Jefecito87
the mass air flow and the OEM air box has a tiny ***** inlet which i hate i jsut dont want to take the bumper off to change alllllll of it
Old Nov 2, 2008 | 08:10 PM
you hate it? too bad, thats the way it is.
There is a lot of science going on, and obviously you have zero clue about how ur car works.
Go do homework b4 anymore stupid attempts.
Old Nov 2, 2008 | 08:11 PM
expo1's Avatar
He's as bad as Can
You should learn more about the car before you attempt to reengineer it. Your mod made you 8 run worse. While the noise the OEM intake makes might not be to your liking, the airflow is fine. In fact it changes based on need.
Old Nov 2, 2008 | 09:02 PM
jefecito87's Avatar
Jefecito87
i know somewhat about the car i stripped down my friends when he totaled it i just love the way it sounded my old g35 never sounded close to this one lol and thanks ill fihure it out ill just buy one from one of the sites i just want it to sound a little better i oredered a catback and an intake would finish it right off
Old Nov 3, 2008 | 02:15 AM
2SeeKU's Avatar
Aussie
Some advice: Unless you know the in's and out's about the right volume and flow rate for the size of our motor at the right RPM, l'd suggest buying an off the shelf model. Do a search and you'll find plenty of reviews by the guys on here.
e.g: Injen
Old Nov 3, 2008 | 02:33 AM
e.g: Injen
wow,,
all your knowledge yet you fail...
sorry.
seems like you know little. but are good at grammar.. good job..
Old Nov 3, 2008 | 02:40 AM
kersh4w's Avatar
Hit & Run Magnet
aem cold air intake. or mazdaspeed. they are the same.
Old Nov 3, 2008 | 02:48 AM
2SeeKU's Avatar
Aussie
Originally Posted by swoope
wow,,
sorry.
Thanks, it's good to know l'm good at something.
And can you correct me where l went wrong, rather then just saying fail? That just comes across as obnoxious.
Old Nov 3, 2008 | 02:54 AM
well you little link is just wrong..
https://www.rx8club.com/showthread.php?t=158795
that is a silly little thread about intakes.. with knowledge, and testing..
read the whole story.. knowledge is power.. not really the best choice.. wait it is the same link, but you did not read the end..
go figure.. stuff like that is around here..
Old Nov 3, 2008 | 02:56 AM
2SeeKU's Avatar
Aussie
Ahh, now l understand. Cheers.
Didn't mean to sound like a dick either...
Old Nov 3, 2008 | 03:14 AM
I <3 Sushi
I'm going to be nice and suggest a solution that "might" work.
There are these screens before the MAF. Those screens are to straighten out airflow so that the MAF can read the air correctly. Without those screens, you're going to get a weird idle problem like what you mentioned back in your original post.
Try putting in one of those screens that's in the stock intake infront of the MAF, that should help.
RevMeHarder
Jun 1, 2026 02:30 PM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
Octomus
Sep 3, 2015 11:40 AM
