View Full Version : Restoring Black Plastic Trim on the Rear Bumper
Nopstnz8 10-29-2008, 08:11 PM My bumper trim is starting to look white on the exhaust shrouds. I am assuming this is a result of the heat from the exhaust drying out the shrouds. Anyways, I am looking for a product to make them look like new. I have tried Aerospace 303, which works great except on the shrouds, Mother's back to black, and will soon be trying Klasse plastic treatment. I am looking for something that I don't have to apply every week I wash the car because it is time consuming. Will Forever Black trim dye work well on our bumper? I also heard that Black Wow isn't very good. If none of these will really work, would replacing the shrouds be a near perfect match to the rest of the bumper? Any advice would be greatly appreciated. Thanks.
dothackRAVE 10-29-2008, 11:46 PM Back to Black. I know you've used it before, but it really just takes like 5mins to apply and forget.
05rex8 10-29-2008, 11:53 PM Mine are doing the same thing....I've just accepted the fact that if I want to have aftermarket exhaust, they are not going to be perfect....
I guess I could extend the tips...
swoope 10-30-2008, 01:41 AM 303 areospace..
search google or here..
really good stuff..
beers :beer:
Ross_Dawg 10-30-2008, 03:17 AM I have tried Aerospace 303
303 aerospace..
:uhh:
swoope 10-30-2008, 03:30 AM :uhh:
wow,,
got you.
if that product does not hold up... you have issues...
maybe replace the shrouds...
beers:beer:
joe-jitsu 10-30-2008, 01:11 PM I second back to black. It also helps to work it in with some love, in the shade when the surface is cool.
Now if its from exhaust heat its may not be very repairable, maybe some spiffy chrome exhaust finishers, or some new plastic ones as suggested.
Razz1 11-04-2008, 11:30 PM That's it. I third that. Now that the election is over worth. Get back to work.
nuke0907 11-05-2008, 01:46 AM you should get them sanded smooth and painted.
Rollinwithrotary 11-05-2008, 02:29 PM Id go with the mother back to black too.
Alucard 11-11-2008, 07:30 PM Check this place out:
http://www.properautocare.com/reswhitstain.html
http://www.properautocare.com/exterior-trim.html
Ive actually used forever black and it works great... then I follow up with meguiars trim detailer...
http://www.meguiarsdirect.com/product_detail.asp?T1=MEG+G10810
Nopstnz8 11-12-2008, 04:39 AM Thanks guys. Especially you Alucard. That is exactly what I was looking for.
Renesis07 11-12-2008, 10:47 AM Im in the same boat, mine are starting to look shabby.
Alucard 11-17-2008, 03:38 PM no problem guys... glad to help :)
Spoolin8 12-28-2008, 03:21 AM i actually use a tire gel spray thats meant to make the tires look all black and shiny. Well i tried in on the back plastic trim and it worked wonders. Since its a gel and more oil based it really soaks and smooths on the look and mine is so shiny it almost has a gloss black look to it which looks great against my sunlight silver 8 :)
elcolombiano91 01-05-2009, 07:44 PM i actually use a tire gel spray thats meant to make the tires look all black and shiny. Well i tried in on the back plastic trim and it worked wonders. Since its a gel and more oil based it really soaks and smooths on the look and mine is so shiny it almost has a gloss black look to it which looks great against my sunlight silver 8 :)
+1 same thing i do on my SS
heyarnold69 01-05-2009, 08:05 PM i just wish my plastic was painted BB
DrewMan 01-06-2009, 04:06 AM how about those chrome shrouds that are an OEM option?
then paint them black or soemthing
DOMINION 01-06-2009, 09:52 AM Mine are doing the same thing....I've just accepted the fact that if I want to have aftermarket exhaust, they are not going to be perfect....
Same here. When they start to look like they are melting I'll change them out.
DOMINION 01-06-2009, 09:53 AM how about those chrome shrouds that are an OEM option?
MM (Jeff) has them they just burn after time. Wast of moneyz + you cant see them if you have 3" exhaust tips
416to212 01-06-2009, 10:44 AM Haven't really noticed much whitening between washes since I started to use Turtle Wax ICE on my black bits. The shrouds come out looking deep black but not shiny and they stay that why for at least 8 months. It also helps with the water spotting issue on the lips below the fake grills.
I've used ICE with both the stock and my Greddy and all was good. Maybe a combination of Back to Black and ICE would be a good solution. One makes it black the other protects it.
i used 99% alcohol and it never came back, i tryed 70% - 80% and that didnt work, try 99%, its really from the waxs and cleaners that make it like that, you have to strip it off
Jedi54 01-07-2009, 12:59 PM Meguiars NXT has a purple spray bottle that works REALLY well for black parts. Apply a small amount on a cloth or applicator pad and you should be fine.
416to212 01-07-2009, 02:42 PM i used 99% alcohol and it never came back, i tryed 70% - 80% and that didnt work, try 99%, its really from the waxs and cleaners that make it like that, you have to strip it off
I'd suggest that you don't have hot tips during the process....
Where do you get 99% Alcohol? Is this household stuff?
my job, i work for toshiba, and it cant have any water in it for logic boards and other electronics, its really great stuff, i clean rollers that turn white and it gets it black, im sure you can find it on ebay, i dunno
Gauge 01-07-2009, 08:16 PM Am I the only one who uses black magic? lol
heyarnold69 01-07-2009, 08:34 PM no, your the only one who posted cause most people just agreed...
extremsprt86 01-08-2009, 02:25 PM peanut butter! i know it sounds redic, but rub it on, wipe it off, and your all set! black as new!
dozer 01-08-2009, 02:29 PM ^you gotta be bullshittin, im gonna have rats following my car at 60mphs
Renesis07 01-08-2009, 03:54 PM peanut butter! i know it sounds redic, but rub it on, wipe it off, and your all set! black as new!
lol, can anyone verify this?
Alucard 01-08-2009, 05:31 PM well ive heard that you can clean up gum with peanut butter, and also remove scratches on cds with peanut butter.... so who knows lol
dothackRAVE 01-09-2009, 07:15 AM It's probably more of a result of peanut butter oil than the peanut butter itself. Oil makes plastics shiny.
extremsprt86 01-09-2009, 09:32 AM the oil is most likely what does the trick, but having it in a nice creamy form makes it easy to put on. ill do a round and put up pix once i get my car back from mazda.
p.s. chunky is killer on a pb&j but for the car stick to creamy, and dont bother trying to use it on the fender vents unless you can take them out to do it.
Gauge 01-09-2009, 01:52 PM What would happen if you added jelly..OoO..
