RX-8 to STX?
Old Oct 29, 2008 | 12:13 PM
Gunner's Avatar
RX-8 to STX?
I haven't found anything official, but is the RX-8 being moved from STU to STX. Has anyone heard any more rumors. Thanks
Old Oct 29, 2008 | 12:17 PM
GlenAnderson's Avatar
Lurker
It is official...look in the fast tracks from either sept. or oct.
Old Oct 29, 2008 | 12:51 PM
Gunner's Avatar
Thanks - I obviously missed that one.
Old Oct 29, 2008 | 01:00 PM
chiketkd's Avatar
Row faster, I hear banjos
Correct. 2wd cars are also allowed 265 tires in STX for '09.
Old Oct 29, 2008 | 01:22 PM
RK's Avatar
RK
It's Not Easy Being Green
I thought the FastTrack had errors in it including some rule changes that hadn't been approved? No idea if the RX8 move or the tire/wheel size changes were included...
EDIT here's a couple notes on the errors. Changes that affected the RX8 were correct so we now have open season on STX with 265s:
http://www.scca.org/documents/Fastra...k-nov-solo.pdf
Old Oct 29, 2008 | 01:51 PM
PBlue's Avatar
Dial P for Phantom
i read em all aug sep oct nov, where does it actually say that rx8s are good for stx now?
Old Oct 29, 2008 | 02:04 PM
RK's Avatar
RK
http://www.scca.com/documents/Fastra...ck-oct-bod.pdf
STX changes that would affect the RX8:
ITEM 14) Change 14.12.4:
“Rims (wheels):
2WD (FWD or RWD):
Width – 9” maximum
Diameter and offset – unrestricted
SCCA Fastrack News July 2008 Page 4
AWD:
Width – 8”
Tires:
2WD (FWD or RWD):
Width – 265 mm maximum
AWD:
Width – 245 mm maximum”
SCCA Fastrack News March and August 2008
ITEM 15) Replace Section 14.12.7:
“Non-standard brake rotors may be used provided they are of equal or larger dimensions (diameter and thickness) and made
of ferrous material (e.g. iron). Aluminum rotor hats are allowed. Cars originally equipped with solid (non-vented) rotors may
utilize vented rotors. Cross-drilled and/or slotted brake rotors may be fitted provided all such voids are within the disc area,
and comprise no more than 10% of that area. Brake calipers and mounting brackets may be replaced provided they bolt to
the standard locations and the number of pistons is equal to or greater than standard. Drum brakes may be replaced with
disc brakes of a diameter equal to or greater than the inside diameter of the standard drum. Such conversions must be bolted,
not welded to the axle/trailing arm/upright. Changes to backing plates/dust shields/brake lines to accommodate these
changes are permitted but may serve no other purpose.”
SCCA Fastrack News June, July, and August 2008
ITEM 16) In 14.12.9, remove from the list of excluded cars:
Mazda RX-8
Items affecting the RX-8 if you stay in STU:
ITEM 17) In 14.13, change second sentence to read:
“…and the maximum tire width is increased to 285 mm for FWD or RWD vehicles…”
SCCA Fastrack News August 2008
Old Nov 8, 2008 | 02:22 AM
Fathead_03's Avatar
VRX8
free post - drunk roommate got ahold of my laptop
Old Nov 10, 2008 | 06:33 AM
Imp's Avatar
Imp
What's next?
Yeah. You need to lock that down.
Old Nov 17, 2008 | 01:40 PM
NordicGreen's Avatar
Born to accelerate.
I'm looking to campaign my '04 in STX in 2009. I'm thinking the new Direzza Star Specs are my best bet for a tire. Will 265s fit on the car? I thought we had trouble with 245s before. Goodness! Any idea on an appropriate aspect ratio?
I'm not sure about 17" vs 18", either. Hmmm...
Old Nov 17, 2008 | 03:07 PM
TopGear8's Avatar
mkuhnracing.com
So if i had 17x9 with 275's in the rear I wouldnt be able to be in STX...what class would that put me in?
Old Nov 17, 2008 | 03:20 PM
Born to accelerate.
That would be STU. 2wd cars are allowed 285s there now.
Old Nov 17, 2008 | 09:58 PM
TopGear8's Avatar
mkuhnracing.com
^Yeah thats what I assumed it would be. Thanks.
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brokegang
Jan 3, 2016 12:45 PM
arexatemate
Oct 9, 2015 06:23 PM
Chapsy
Sep 22, 2015 09:57 AM
Tsurugi
Sep 7, 2015 08:27 PM
