View Full Version : DIY CAI question
peckax
10-25-2008, 01:10 PM
I bought some eBay pipes, and I made my own CAI. it goes through the stock airbox because of the sensor. Though the pipes i bought were 2.5" Which is narrower than what the stock or even aftermarket intakes are. So i had to use a reducer. My question is would this cause any problems/performance loss as the pipe is lower in diameter?
Silver_Mazda09
10-29-2008, 09:42 PM
Making your pipes smaller, would cause air flow problem and easier to heat up quicker under the bonnet. good luck.
Jon316G
10-29-2008, 09:50 PM
AEM uses a 3.5-3.0 reducer coupler on their intake setup.
I wouldn't restrict airflow anymore than that.
em1turbo
10-29-2008, 10:23 PM
bad idea dude.
05rex8
10-29-2008, 11:42 PM
won't that mess with the MAF too?
shaunv74
10-30-2008, 12:08 AM
What is the formula for Mass Flow rate? What does Diameter do to it? Once you figure it out you'll have your answer.
peckax
04-13-2009, 06:31 PM
ok guys, now i ave another problem, i was DIY another CAI just right now with 3.5" pipe. also i made a short ram intake. made my own fire wall or heat shield, drilled hole for a sensor in the pipe and using epoxy atached sensor mount.when i put everything together i start the car and runing after couple seconds turns off. and when i try to step on gas it dies right a way.does anyone knows what is wrong this time? is the pipe too big?thanks
Red Rex
04-13-2009, 07:15 PM
You could potentially throw off your MAF sensor readings, and loss of power would be the least of your problems.
peckax
04-13-2009, 09:46 PM
Throw off the sensor by what? By having a 3.5" pipe? is that too wide in diameter? Please explain.
Jon316G
04-13-2009, 10:15 PM
Any pipe size different than OEM will need to be tuned for the larger/smaller size.
This will throw-off the MAF sensor.
Easier to just keep it the same.
