Carbon Build up
Old Oct 24, 2008 | 11:24 AM
Sushi's Avatar
Carbon Build up
Wanted to get your guys opinion on this, sounds like the dealer is trying to bamboozle me again. I took my car in for the horrible vibration and for the weird dripping noise that is really lound that I get on the right side of my dash when it rains yet ther eis no water in there. Anyways, he said they noticed alot of carbon build up on the parts that werent swapped out from my remanufactured engine I got about 9 months ago. Said it would be around $120 or $130 to clean. I asked him about the Service Notice that I thought it was done once under the recall or the Service Bullitin or something. He said no, and then I thought well, how did you notice this after I have had my car in the shop atleast 6 times in the last year.
I have a feeling they are trying to get me to pay for something that istn really needed, anyone else run into this? Or know if this should be covered under the waranty?
Old Oct 24, 2008 | 11:26 AM
Renesis07's Avatar
Vtak just kicked in yo!!
What is your driving style? If you hardly ever redline, then a decarb may be needed. I would take on a backroad and drive the **** out of it and burn some of that **** out of the engine.
Old Oct 24, 2008 | 11:30 AM
Sushi's Avatar
Well I dont know what the previous owner did, but since I have had it I try to redline atleast once a day, if not atleast every few days. Would Redlining it alot on a single drive really help do that?
Old Oct 24, 2008 | 11:45 AM
CyberPitz's Avatar
Huge hole is huge
It's common belief that redlining helps to remove or even prevent some Carbon Buildup. There are some people who don't think it works. How much you should redline, well, that's up to you. I have a tendency to do it at least 3 times a day. It's fun, and I believe it's healthy!
Old Oct 24, 2008 | 11:51 AM
Sushi's Avatar
I know the redlining works, I do it almost every day, my question is that is there is already a build up like the dealer claims will doing a lot of extra redlining burn it out? I thought it was only preventive, that it wouldnt clean it out after it is already there.
Old Oct 24, 2008 | 11:52 AM
Ryoma-kun's Avatar
Why buy an Rx-8 if you don't even redline it once a day? If I didn't, I'd rather get a VW Polo 1.2 or something.
Old Oct 24, 2008 | 12:00 PM
Renesis07's Avatar
It will "burn it out"
Old Oct 24, 2008 | 12:01 PM
Socket7's Avatar
ಠ_ಠ
Theres a point of no return I'm sure, but it can clean out accumulated gunk if someone hasn't been keeping the engine up in the high rev ranges enough.
If you want to save money and still do the decarb, you can buy the stuff and do it yourself at a fraction of the cost. NYGPS has a good DIY about that. I think the engine cleaner costs like 30 bucks.
My gut would be to do it yourself. I've seen some very nasty looking photos of intakes and ports, and it's entirely possible that they're gunked up again if you've had the engine replaced for a carbon related issues in the past.
Have they checked your motor mounts yet? seems to me like thats a more likely place to find a severe vibration.
Old Oct 24, 2008 | 12:07 PM
Sushi's Avatar
Yes, they said it looks like the motor mounts were loose when they installed the reman engine. I will take a look at the DIY, thanks for the heads up. I will also try redlining more often. I already do it about once a day, I will try and do it twice a day to work and back, to stay on top. Thanks for the info, everyone.
Old Oct 24, 2008 | 12:08 PM
tunerwannab's Avatar
A can of seafoam is like $8. And yes it does make a difference.
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/seafoam-video-155439/
Old Oct 24, 2008 | 01:27 PM
BrrrwWaaaARRr ! NYCGPS is here~
go find my DIY, tells ya what u need to do.
Oh for ur question, oh yes they want your money
If u're under bumper to bumper warranty, it should be free. I know my dealership did it to my car, twice within 5 months. (last month and april)
Old Oct 24, 2008 | 01:31 PM
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-mazda-zoom-power-engine-cleaner-engine-cleaning-seaform-142852/
Old Oct 24, 2008 | 02:19 PM
Socr8tes's Avatar
My advice, FWIW: decarb your engine yourself with Seafoam. The cost with vacuum hose is less than $10. Go through the procedure once and you'll be able to do it in 5-10 minutes in the future. Then go back and have them check the engine mounts AGAIN.
Old Oct 24, 2008 | 04:10 PM
zoom44's Avatar
oh and that sort of dripping sound is probably air in the heater core. it can be bled/burped out
Old Oct 24, 2008 | 08:51 PM
daisuke's Avatar
rotorized!!!
a cheaper way to clean out your engine is to drive it around in high revs when it's really foggy out.
You depend on the weather for it to happen, but if it's very thick then just go out and run at 5k rpms in 1st gear, there is little better for cleaning out carbon than just plain water.
I'd do the seafoam myself, altho for some reason I've never been able to get the car to smoke really bad when I've used it, and this has been on 3 cars so far.
Old Oct 25, 2008 | 08:01 PM
04RX8man's Avatar
Rotary Powered Countryboy
Seafoam=mazda's Decarb!!!!!
$8 Vs $130
The Final Answer Is Seafoam
Old Oct 26, 2008 | 01:05 AM
as you dont mention where you are from or year or mileage.
how could one help you???
Old Oct 26, 2008 | 01:29 AM
Old Oct 28, 2008 | 12:00 PM
always.anthony's Avatar
is looking for his torque
redlining opens up all the exhaust ports.
helps with carbon build up.
its fun + healthy do it!
Old Oct 29, 2008 | 07:26 AM
Sushi's Avatar
Grabbed some Seafoam and am going to try it this weekend. I have been redlining it about 3 times a day since Saturday. They fixed my engine mounts and the vibration is gone thankfully. Thanks for the tips. I will try the DIY and see how it works.
Old Oct 29, 2008 | 07:58 AM
ALL BOW DOWN TO DA KING ! (me)
muHahahahahHAHAHAHAHA !
Old Oct 29, 2008 | 09:03 AM
gsmith's Avatar
I just bought a 2004 6spd RX-8 on Saturday with 41k miles and first off let me say I am loving it and I'm glad I found a great forum like this to help me learn about my new car.
With that said, I am also getting what sounds like some water flowing through pipes behind the dash in front of the passenger seat. How would I go about "bleeding/burping it out"? Or is this something normal that I should not worry about?
Also, my car sometimes idles a little roughly, usually at about 8-900 rpm's. If I give it a little gas to bump it up to the mid 1k rpm range, it smooths out completely, but the rough idle is both annoying and disconcerting. Is this problem a candidate for seafoam?
Old Oct 29, 2008 | 09:25 AM
ZumnRx8's Avatar
RX8 & RX7 owner
i redline as much as my AT lets me...at some times..when i just wanna hear it scream
Old Oct 29, 2008 | 08:06 PM
Old Oct 29, 2008 | 11:50 PM
Originally Posted by tunerwannab
muhahahaHAHAHAHA !
