Autoexe Sways questions (or any sways)
Old Oct 20, 2008 | 11:19 PM
I have a set of Autoexe sways, front and rear.
Hmm, now how to tell if its the right way to install ?
when I flip it upside down and it seems to be the same, but "expo1" had a problem when he was installing the RB sways, he flipped it upside down, installed, then he has to take it back out and install it again. and I dont want that to happen to me. (cuz it seems that I have to take the radiator hose out b4 I can take the sways out. coolants are expensive )
planning to do the sways change on wednesday.
any help would be appreciated. Thx
Old Oct 20, 2008 | 11:26 PM
NgoRX8's Avatar
there's no problem with the front.
it's the rear that can be installed upside down.
Old Oct 20, 2008 | 11:31 PM
sweet .... I jsut re-read expo's diy. ur'e right. So I guess no fear
rear is a piece of cake. its the front thats a pain in the butt.
thx a lot
Old Oct 20, 2008 | 11:48 PM
NgoRX8's Avatar
have fun man. it was a pain squeezing that front bar into place.
Old Oct 20, 2008 | 11:51 PM
Now you just made me worry more. I hate you !
Old Oct 21, 2008 | 12:18 AM
NgoRX8's Avatar
nothing to worry about. hahaha! just a PITA.
Old Oct 23, 2008 | 01:34 PM
Installed, some notes
Autoexe Sway bar has been installed.
There are a few things to pay attention to
The Autoexe Front bar, in fact, can ONLY be installed 1 way. both side has a little tab to tell you which way it goes. after you install it, if you can not turn the bar up and down. you installed it wrong, take it back out and put it the other way.
Also, when installing the end links, you should put it into the bottom hole first (mount to the chassis) before You try to mount it to the bar. much easier that way.
For the Rear bar, there is almost no way that you can flip it upside down, take the old stock bar out, and put it down the floor the way it is, put the new bar next to it, and u will be able to tell which way is the "right" way.
hope it helps future noobs
Old Oct 23, 2008 | 01:36 PM
how's the car feel?
Old Oct 23, 2008 | 01:43 PM
it feels great. Now the Responds are much quicker. seems to have less body roll. need more tests to confirm. but winter is almost here so might have to wait until next spring
Autoexe sways have 2 settings (2 holes), one is 120%, the other is 140% (compare to stock) I set both front and rear to 140%
I didnt use Stock endlink(its all broken even b4 I took them out, maybe thats why my car handle like **** at the track day, gonna ask and see if I can warranty those later) replaced them with Autoexe endlinks. Its much stronger and shorter than stock endlink. not sure what the effects are tho.
Brokegang
Jan 3, 2016 12:45 PM
OfficerFarva
Dec 5, 2015 10:53 AM
jer2911
Sep 29, 2015 06:37 PM
Steve Dallas
Sep 19, 2015 09:39 AM
