8 woes..
Old Oct 20, 2008 | 09:35 AM
DarkLord7854's Avatar
Software Engineer
8 woes..
So after finally getting the new tranny in to fix my problems with 3rd and 6th gear, I've put 1,000 miles on it (on top of the 700). I've driven it fairly nicely, I haven't raced it, drifted, or shifted like a maniac. Been fairly gentle with it.
Except it seems I wasn't gentle enough.. 3rd gear will now refuse to engage unless I skip it and go into 4th, and then back into 3rd.
If I'm downshifting, I have to go into 2nd, and then 3rd.
Occasionally it'll work fine, but it feels like it grinds even though there's no noise.
So I called MazdaUSA back, and they immediately started quizzing me on whether I race it, modify it, blah blah.
Now, it turns out, my dealership has closed it's doors. Not that they were great or anything, but I have to take my 8 about 50miles North now.
I'm starting to think the 8 they gave me is round, yellow, sour, and citrus flavored..
Old Oct 20, 2008 | 09:37 AM
TurboEight's Avatar
Booost.
09s too....sadd....
hope you get your problems solved..
is MazdaUSA same as mazda NA?
if it ain't, give NA a call.
Old Oct 20, 2008 | 09:54 AM
Software Engineer
Ya, same number
Old Oct 20, 2008 | 12:05 PM
dozer's Avatar
on his 3rd rx8
damn....
Old Oct 22, 2008 | 10:08 AM
Software Engineer
Well, took it to dealership, they said it's "perfectly normal." I wasn't aware that gears 1-4 were supposed to be 2-4x rougher than 5 and 6 when engaging them, and that 2nd and 3rd were sometimes supposed to not let me shift into them.
(Yea.. it has worsened since I posted the thread).
But hey.. what do I know, they say it's normal and the car is perfectly fine. It doesn't feel fine at all, far from it.
Not exactly sure what to do now..
Old Oct 22, 2008 | 10:56 AM
Renesis07's Avatar
Vtak just kicked in yo!!
Dont mod it, sounds like youll be needing your warranty
Old Oct 22, 2008 | 11:01 AM
Software Engineer
Wasn't planning to until I buy it either way.
Old Oct 22, 2008 | 06:37 PM
mmats69's Avatar
93.5 octane
sounds like they never fixed the tranny problem over the years. had the same thing happen in my 04. going home one evening, could no longer shift into 3rd. but mine was the original transmission.
Old Oct 22, 2008 | 06:43 PM
Renesis07's Avatar
my tranny was a nightmare, the day it blew at 30K miles was a dream come true. My new trans has been great! It has a small leak but no problems and I drag race and drive like an ***
It has a warranty, let the bitch blow then get a new one.
Old Oct 22, 2008 | 06:49 PM
rotary.enthusiast's Avatar
The Local Idiot
Keep in mind that he has an '09 which has a totally different transmission than previous 8's, so past experiences may not apply.
Sorry to hear about your problems... I had heard some good things about the new transmission compared to the original, but it doesn't sound like you're having any luck
One thing you might want to check is if the clutch pedal is adjusted properly. If the clutch isn't quite disengaging all the way it will cause hard shifts and wear out your synchros.
Old Oct 22, 2008 | 06:57 PM
ferg's Avatar
how long dose it take for the rx8 to fail all around? lol i hope not, everything seems ok on my 06 with 12500 miles, i have a question. what about the 8 year warranty or 100,000 miles, on the rx8, can i take my car any dealer with out paperwork? or how much would they change me to just look over the car?
Old Oct 22, 2008 | 07:09 PM
Renesis07's Avatar
depends, some dealers offer "free inspections", or it could be 80-100 for an inspeciton and/or diagnostic. Next time your in for an LOF, tell the advisor you would like for the tech to look it over and a copy of the inspection sheet. Theyll usually do that at no cost.
BTW, theres no set 'death' date to an rx8, its like any other car. It depends on the driver, your maintanence, etc. Mine is an 04 with 71K with no engine problems.
Old Oct 22, 2008 | 07:12 PM
ferg's Avatar
lof? im getting a warehouse with a lift when i can so i can do all the work my self but till then ill deal with dealers lol
Old Oct 22, 2008 | 07:17 PM
I8U's Avatar
I8U
They have improved it...but there are very few out there and to be honest, some of the builds weren't the greatest. I can tell you this, the ones we have had in our race cars work like a champ! Give it some time, still gotta work the bugs with the new tranny.
Old Oct 22, 2008 | 07:18 PM
Renesis07's Avatar
LOF= Lube. Oil. Filter. (Oil Change)
