blkswan
10-19-2008, 12:54 AM
Could someone plz help answer my question?
How much would the dealership or a bodyship charge me to install the aero package: front air dam, side flares and rear?
I just wanted to know so I can estimate how much I will be spending.
Also I looked at the instructions on how to install the rear flare....it look sooo complicated...is it actually easier than it is in the manual?
Thanks for all your help.
yushinrt
10-19-2008, 02:30 AM
depends how good at you installing stuff but it pretty easy to put oem stuff since they are made close to perfect
TopGear8
10-19-2008, 02:44 AM
Yeah man seriously it's not hard at all...Find a DIY and do it yourself.
yushinrt
10-19-2008, 02:47 AM
i used to be like you blkswan when i just got the car but after doing it few times.
if you don't have a tool go buy a 8mm,10mm screw driver
blkswan
10-19-2008, 05:39 PM
Thanks everyone for the responses. Sounds Great. Im just worried because Im one of those guys that ends up putting together furniture bought from ikea all f*cked up., ie. screws in the wrong place, boards loose, etc.
hopefully it will come out ok =P
yushinrt
10-19-2008, 05:46 PM
blkswan good thing about the car is that the screw is all ready there and hole allready line up perfectly. so it easy to take out and put back togeather it lot easyer then making model trust me :)
it close to making lego just follow instruction and everything will be good.
another tip is that since it your first time do it when you have spair time,mean do it when you have lot of time free, that way you can relax and take time , as well as it would help if you get a jar or something to put all the screws in it, if you need any help just post a replay to the forum
