MMO as per carbon TSB-REVIEW
Old Oct 16, 2008 | 09:26 AM
max5roadster's Avatar
INDY RX8 CLUB - Officer
Well since nothing I have done so far seems to be able to raise my hot idle vacuum from 15", I thought I'd give one last shot at decarbing. Instead of seafoam, I have seen numerous references on the 7 club forum (and few on here) about using MMO in the same manner. So I basically "hydro-locked" the car with MMO and let it sit last night. Started up this moring and got MORE smoke than seafoam...and it stinks twice as bad! Well, let it run for 20 minutes in the driveway. Drove like I stloe it for 20 minutes, and I am still getting smoke when engine is under vacuum, but it is clearing up. ?Going from white to blueish, just as seafoam does before it all burns out. It is certainly lingering much longer than seafoam and I have pretty sooty tail pipes now. I dont recall having this build-up with seafoam. I checked my vacuum and itr is still 15, so no change, but the car did feel a lil smoother thru the rev range....but in the end, it has done nothing, but make a bigger mess than seafoam. I will continue to use it at 6-8 oz every fill-up, but not as a replacement for seafoam.
Old Oct 16, 2008 | 11:06 AM
By chance does anyone know how long this stuff takes to burn off? I have run the tar out of it and am still getting those nasty fumes with plumes of blue smoke. I may run a can of seafoam thru just to clean it all out I have no noticable change vacuum or drivability... Just stinks to holy hell and looks like a car with a burn pistion ring.
Old Oct 16, 2008 | 05:57 PM
olddragger's Avatar
you dont have a cat do ya? that much mmo--can it hurt a cat? Just go to the dealer and get the decarb stuff--in a can/kit=--about $20 -it works the best.
15 of vacuum at idle--means --you know. check it at 2K no load also. it should be about the same.
OD
Old Oct 16, 2008 | 09:25 PM
cant fix whats already broken ?
Old Oct 16, 2008 | 09:32 PM
I ran a can of seafoam thru and sure enough, all the smoking has stopped. I dont have a cat, so I'm good to go there. I changed the oil after the seafoam rinse and rechecked my vacuum at hot idle twice and got 16 steady the first go and 15.5 the second check. I know the vacuum #s are low, but I have no powerloss issues or stalling...
Just for comparisons, had some club members over today and did an 04 reman'd auto that had 30K on it and it pulled 15.5-16.
Also had an 04 w/41K pull a rock steady 17".
Funny thing is my car feels stronger (according to the other club member) than his healthier engine...
Old Oct 16, 2008 | 09:33 PM
Rote8's Avatar
I see your sig shows a B&B mid pipe.
If you do not have a cat, go to Walmart and pick up a quart of "CD2" (a lead substitute) in their automotive section. Premix two Oz per tank of gas and watch the vacuum slowly rise, after about three tanks, you should see a good bit more vacuum.
Old Oct 16, 2008 | 10:25 PM
Old Rotor's Avatar
Would any deposits on the plugs appear and how often would you have to run it?
Old Oct 17, 2008 | 02:58 AM
Nubo's Avatar
Lubricious
Did you purge most of the liquid out of the sparkplug holes, or just run it into the exhaust?
MMO has a lot of seafoam-type solvent, but does also contain oil, which is why it's a better smoke-generator.
Old Oct 17, 2008 | 12:14 PM
I was waiting to see olddraggers trial results.. But, I do have a can of the Gunk lead substitute ready and waiting.
Old Oct 17, 2008 | 01:10 PM
olddragger's Avatar
did you check the vacuum at 2K and no load?
OD
Old Oct 17, 2008 | 10:23 PM
honestly no not yet, but I know it goes up w/ throttle increase as I was seeing what kind of vac it was getting while lifting the throttle... Why?
Old Oct 18, 2008 | 08:06 PM
olddragger's Avatar
2 K vacuum should be about the same as idle vacuum--at least on recips it is. if it is higher--now it has to be a steady state no load(as in driving etc) 2k reading.
if it is higher at 2K then it may not be wear related.
OD
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
GK1707
Sep 27, 2015 07:33 PM
