Security sensor stopping the engine from starting??
Old Oct 14, 2008 | 11:26 PM
Boardmanrx8's Avatar
Start it up...Hold on
Exclamation Security sensor stopping the engine from starting??
I have read many of the posts from here and still wander about this problem:
At times, and this varies WIDELY, my engine will simply not start, not even turn over. As an example, the other day I took my daughter back to college. A beautiful fall day here in the northeast so I took my 04/6 spd out for a ride. 53 miles, so the car got plenty hot. We arrived and went on a tour of the new apartments she is considering. Upon coming back out I went to start the car and NOTHING....All I got was th flashing security light. Now this has happened in the past along with it stalling out while driving. The very first time I took it into the dealer was told that there was an "open circuit" found and fixed. That seemed to solve the problem and I had driven this not even thinking about it this whole year...untill the other day when it happened again.
This time was a little different though as after getting just the security light and no ther lights... I kept on turning the key....while hearing some promising "clicks" and finally getting some other dash lights on....and it finally did start. I drove it the whole way home with no problems and it has been "normal" since. Again I took it in to the dealer and was told that nothing was found to be abnormal from the starting celenoid to the starter.
I don't know what the circumstances are with "flooding" but it seems that I get NOTHING when I turned the key except for the security light still flashing - NO other lights appeared.
I know there is a chip in the key and am wandering if that is going bad - is the simple solution to use my other key?
ANY help would be GREATLY appreciated as I travel a lot and want to make sure that when I turn the key over the car starts.....
THANKS...!!!!!
Old Oct 15, 2008 | 10:50 AM
olddragger's Avatar
check the battery and all the connections---then if they are ok check the clutch switch to make sure it is functioning correctly.
Dont think this is a security problem.
That would be weird
OD
Old Oct 15, 2008 | 10:56 AM
EdwardsB's Avatar
Registered RX-8 User
check the wire connection in the steering column to the security chip receiver. It is wrapped around the key hole. Its worth the quick check.
Old Dec 26, 2008 | 04:21 PM
diabolical1's Avatar
i'm the undead
okay, quick question ...
if the security module is bad/fried will that prevent the car from starting? my module is done - that's confirmed and i removed it, however i just finished replacing some other parts and went to start the car and nothing ....
i'll probably try push-starting it later, but i wanted to find out if the module will prevent it from starting first.
Old Dec 26, 2008 | 04:50 PM
zoom44's Avatar
the pcm is waiting for an ok from the module that isnt there
Old Jan 8, 2009 | 04:48 PM
Jonathan11's Avatar
Pain Is Weakness
My car did the same thing today at work, I had to push start the thing, when i turn off the engine it makes a weird cluck sound, i never thought much about it, but today it would not start. All it did was make the cluck sound and my gauges went haywire. I ended up having to push start in 3rd, I took the car to my uncles shop and I am going to have to miss work tomorrow to work on it =( My guess is its the starter, i am going to start from there. Ill keep you guys posted on this as to seeing how you are encountering the same problem. I would like to know however if when you guys turn the engine off do you hear a cluck noise coming from the engine? Maybe those were signs of the starter going bad. ANy input is appreciated thank you
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
Pelleilee
Sep 29, 2019 10:07 AM
marc2820
Jul 26, 2015 10:47 PM
ironj221
Jul 16, 2015 10:16 PM
